RV.Net Open Roads Forum: Forum Technical Support: Sig Pic
Search only in Forum Technical Support
RVSnowbird
OR-NV-AZ-OR
Posted: 08/11/07 10:43pm Link  |  Print  |  Notify Moderator
B & P, as Tom said, you will have to combine your animated bike picture along with that of your trailer. That will take a more sophisticated graphic program than the IrfanView that I used for the examples in my Resized Panorama etc. tutorial.
I analyzed the bike picture and it is only three elements sandwiched for animation. If you can use the program it was created with and add your trailer picture to each of those, you would then have both in one picture for your signature.
Even combined, your picture sizes will be well within the 500x100 pixel limits but the trick will be to keep it under a file size of 30kb. Animations quite often are very large file sizes.
I hope this helps.....
RVSnowbird
Added in Edit: correction, it is four elements and not three. Here is a crude attempt at what I was explaining above:
I used an animation program from www.whitsoftdev.com to combine these.
Unfortunately, as I said that animations are often very large file sizes, this one is 35kb which would be rejected as oversize....
* This post was edited 08/11/07 11:28pm by RVSnowbird *
bigdodge8
Napa, CA
Posted: 11/28/07 08:32pm Link  |  Print  |  Notify Moderator
can anyone see my pics. Thanks
this is a test
RVSnowbird
OR-NV-AZ-OR
Posted: 11/28/07 08:45pm Link  |  Print  |  Notify Moderator
bigdodge8, you have pictures uploaded to your profile but not your signature as those are uploaded along with text in your Preferences, via your My Forums page.
see Profile and signature pictures for an explanation.
However, if you don't see any signature pictures, that is a Preference setting that may be turned off. While there, scroll down and check:
Show members signatures when viewing topics.
Look over the rest of your preferences and if you make any changes, click on "Submit Changes" at the bottom of the page.
RVSnowbird
bigdodge8
Napa, CA
Posted: 11/28/07 09:00pm Link  |  Print  |  Notify Moderator
Thanks, not to good at this but ill get it.
this is a test
RVSnowbird
OR-NV-AZ-OR
Posted: 11/28/07 09:36pm Link  |  Print  |  Notify Moderator
perhaps this will help bigdodge. This is a resized version of the photo in your profile:
Right click on it and select "Save picture as" to put it into your computer. Next, go to your Preferences and click on the Browse button to upload it. When done, go to the bottom of the page and click on "Submit Changes".
Any changes made to a signature will show in all past, present and future posts. You need only go to your profile or a recent post to verify your changes. That is providing you have Append Signature checked in your Preferences to show with each post or checked with each post you make.
Also, signatures will show only once per topic page view in all forums except this one of Forum Technical Support where it will repeat with each post.
RVSnowbird
wolfsontheprowl
SE WI - USA
Posted: 11/29/07 06:13am Link  |  Print  |  Notify Moderator
Looks like I'm experiencing the same problem with signature. I do not recall doing any changes on "My Preferences" page including picture.
see below
Butch and Deb
2008 GMC 2500HD SIERRA 4x4 6.0L 4.10
2003 Fleetwood.RV Prowler 25Y
Equal-i-zer, Barker Hi-Power 3000, Prodigy brake controller
WI Rallys attended - 9 with MORE IN 2009 .....
pulsar
Lewisville, NC
Posted: 11/29/07 07:42am Link  |  Print  |  Notify Moderator
see below
Your signature has a start bold tag, [b], without a corresponding close tag, [/b]. (See picture)
To correct the error, either remove the start tag or add a closs tag a in an appropriate place. Signatures are edited on your "My Preference" page.
Tom
wolfsontheprowl
SE WI - USA
Posted: 11/29/07 08:32am Link  |  Print  |  Notify Moderator
see below
Your signature has a start bold tag, , without a corresponding close tag, . (See picture)
Tom
Thanks Tom, that did the trick. There is usually a simple answer.
Butch and Deb
chewbear
Lindenwold, NJ
Posted: 11/29/07 09:16pm Link  |  Print  |  Notify Moderator
test
New to Us
2002 Fleetwood Discovery
330 cat.
chewbear
Lindenwold, NJ
Posted: 11/30/07 05:02am Link  |  Print  |  Notify Moderator
Test
New to Us
330 cat.
