RV.Net Open Roads Forum: Fifth-Wheels: Keystone Cougar 5th wheel tire problems
 > Keystone Cougar 5th wheel tire problems
Papa Guido
Orange, CA
Posted: 07/30/07 10:34pm Link  |  Print  |  Notify Moderator
I have a 2004 Keystone Cougar 24.5 foot 5th wheel, purchased new. We have less than 10,000 miles on two sets of new tires. The two right side tires both shredded (approximately 4 hours a part) when we were returning home to So Cal from Utah. At the time, we probably had less than 2,000 miles use. On another trip to Baja, a tire blew on the right and tore up the side of the trailer and caused damage to the gas line underneath. We replaced all four tires with brand new heavy duty tires.
Last week we took a 300-mile round trip and the replacement tire on the right side once again shredded causing more body damage.
The problem is only occurring on the right side. The alignment has been checked and appears to be OK. Has anyone experienced this situation and do you have any input?
We love the trailer but are getting frustrated.
PapaBeav
Petaluma Ca
Posted: 07/31/07 12:13am Link  |  Print  |  Notify Moderator
I can only think of two things at this time. Under pressured tires or driving to fast, ( 65 mph max on ST tires ) on hot roads.
Rich & Kathy
2003 Chevy 2500HD D/A CC SB
2006 Montana 2955RL
scbwr
North Ridgeville, OH
Posted: 07/31/07 05:38am Link  |  Print  |  Notify Moderator
Just taking a guess, but could your right trailer brakes be grabbing, causing the tires to heat up. I'd have the brakes checked.
Or....are you overloaded and causing excessive heat? Leaky valve stem causing low pressure while under tow?
Replace valve stems, check brakes....after doing some driving. Get your trailer weighed.
Good luck!
2007 Toyota Tundra 5.7
2014 Winnebago Winnie 2201DS
Equalizer hitch
Celebrating our 27th year of camping!">
"Get busy living, or get busy dying."
Andy Dufresne, The Shawshank Redemption
MrSeven21
Cape Cod MA
Posted: 07/31/07 08:17am Link  |  Print  |  Notify Moderator
I am not sure what your problem might be. But we have a 2004 Keystone Laredo that has Al-Ko axels on it, well back in 04 my camper was eating tires at an alarming rate. after reading about misaligned axels from al-ko on THIS Fourm, I called them. after telling them my axel tag #'s it turns out we had bad axels that were welded at the wrong angle. Al-Ko promtly sent out new axels to my dealer and reinbursed us for four new tires plus all parts and labor.
2004 F-250 Crewcab 6.0 Diesel 4x4
2009 Rockwood Roo
Knick Knack
Shelby Township, Michigan USA
Posted: 07/31/07 01:49pm Link  |  Print  |  Notify Moderator
Alko axles are your problem. Mine were replaced along with 4 new tires under warranty. Call Keystone and they will give you a name and phone numbet to give to your dealer for warranty repair.
Knick Knack
2004 Laredo 27RL
2004.5 Dodge Ram 2500 4X4 Long bed Quad Cab Auto HO CTD
1986 Rinker 21 foot cuddy cabin & 12 foot Porta Bote
1984 Chrysler LeBaron woody convertible
Two Brittanys
pritch272
Martinez, GA
Posted: 07/31/07 03:22am Link  |  Print  |  Notify Moderator
Perhaps the right side has more weight?
2007 Keystone Laredo 29RL, 2000 Ford F250 7.3 PSD, Firestone bags, Pressure Pro, 16" Michelin XPS Ribs, MorRyde Pin Box, Dexter EZ-Flex, PI EMS-HW30C, Dirt Devil CV950 Central Vacuum, 2000W AllPower by Kipor, 4000/3500W Champion C46540
FalconLover
Southern California (Whittier)
Posted: 07/31/07 04:52pm Link  |  Print  |  Notify Moderator
Our tires weren't blowing but they were wearing on the inside edge. After going a couple of rounds with Mike Thompsons and ALKO they replaced our axles too, at no cost to us.
I understand that the axle tubes were under-rated for our trailer. Since the replacement we've had no furher wear issues.
John
The Rutters
2004 Ford F350 Crewcab Lariat FX4 (4x4) DRW
6.0 PSD, Torque Shift, Jack Rabbit roll top cover, Rosen widescreen DVD system
2004 Montana Mountaineer 33' fifth wheel (297RKS) w/double sofa option
1965 Ford Falcon Futura (Pro Street/Driver)
boat jocky
NEWBURY PARK CA.
Posted: 07/31/07 05:09pm Link  |  Print  |  Notify Moderator
hOW LONG DID IT TAKE FOR THAT JOB? IT TOOK FIVE WEEKS FOR A ONE DAY OF NICKLE & DIME WARRENTY THINGS?
stripit
Prescott
Posted: 07/31/07 06:04pm Link  |  Print  |  Notify Moderator
I would strongly suggest getting the trailer weighed by wheel position to insure your not too heavy on one side. I would have your air gauge checked for accuracy, and then make sure your running those tires at the maximum air pressure. Shredding tires is norrmally underinflated, or overload, or a combination of both.
Stacey Frank
'07 Winnabago Class C
'08 Lexus 400H
'15 Cadillac SRX
Blue Ox towing system
Kodiak5er
Alex Bay NY Summer; Sanford FL Winter
Posted: 07/31/07 06:44pm Link  |  Print  |  Notify Moderator
Have you actually weighed your trailer to see what load you are carrying on the tires?
What size tire are we talking about and what weight is the tire rated for?
Nobody can give you an answer until the above two questions have been answered.
You might be using a ST rated tire when you should have a LT rated tire. The difference being the ST tire is only rated for 65 MPH max and the LT tire is rated for a speed that you would never pull the trailer. Most of the newer and heavier trailers are coming from the factory with LT rated tires.
1990 6500 Chevy Kodiak, 8.3L Cummins 450 HP
6sp Allison 3060, 3.70 R/A Home Made Air Ride
2006 Newmar Cypress
Picture of '93 Mountain Aire Story of it's death by fire and explosion
