RV.Net Open Roads Forum: Travel Trailers: best cold weather TT
 > best cold weather TT
mkjk
nor cal
Posted: 08/03/07 12:45pm Link  |  Print  |  Notify Moderator
my wife and i are going to semi-retire to eastern washington/idaho and plan on living in a travel trailer for a year or so prior to purchasing home and property. we will mostly stay in parks with full hook-up and are looking at 26-30 foot TT with 1-2 slides. our questions are...brand with cold weather insulation..snow load..etc. we want to be comfy of coarse. any info will be appreciated.
Kenneth
Washington, the state
Posted: 08/03/07 12:52pm Link  |  Print  |  Notify Moderator
Look at Big Foot and Arctic Fox. Both are very well made as well as being suitable for winter.
Your Old Dog
Western New York
Posted: 08/03/07 01:30pm Link  |  Print  |  Notify Moderator
Doesn't Idaho and that part of the country record some of the lowest temperatures on record? I live in Buffalo New York area and I'd rather try what you are doing here instead of your neck of the woods. I don't think you plan is a sound one as travel trailers just aren't' built for extreme temps for long periods of time. My little furnace would be running all day long. Just make sure you look into it well so you don't bite off more than you can chew.
By the way, I"m not one of the safety freaks who think nothing is every safe enough.
Unless tomorrow has been promised to you, you better get busy today.
downtheroad
Pacific Northwest
Posted: 08/03/07 01:38pm Link  |  Print  |  Notify Moderator
Kenneth above has made some good suggestions.
Also consider Komfort. They are not light weight or inexpensive, but are very well insulated and are built close to where you are going to settle. They also have an excellent choice of floor plans.
Komfort
Arctic Fox 25Y
GMC Duramax LBZ
Blue Ox SwayPro
TUCQUALA
Kennewick, WA
Posted: 08/03/07 02:22pm Link  |  Print  |  Notify Moderator
YOD: Only if the OP is planning on finding a park up in the mountains will they find "some of the lowest temps on record". Eastern WA and Western Idaho, in the areas of major population, have fairly temperate climate. Here in Kennewick, it rarely snows more than a couple inches a couple of times a year. Average temps run from the 20's to the 50's. Yes, we occasionally have a few days of close to 0, but that is less common here than the lake effect snow you get in the winter.
To the OP: Any quality TT with winter pack, as many have that are built here in the NW, should fit your needs. It all depends on where in E. WA, or ID that you are planning landing temporarily.
'16 Outdoors Timber Ridge 280RKS
DrawTite/Reese 1200# Round Bar w/ DualCam HP
'03 EXCURSION XLT V10 4.30 Axles
Nascar24
Blackstone Valley, Massachusetts
Posted: 08/03/07 04:50pm Link  |  Print  |  Notify Moderator
Hi
SunnyBrook Titan with the full arctic package.
Good Luck and Happy Trails
2008 Nissan Pathfinder 4x4 V8
2014 Grey Wolf 19RR Toy Hauler
Nascar24 A lengend in my own mind, A Scary thought in someone else's!
Rick From Sequim
Sequim, WA
Posted: 08/03/07 05:57pm Link  |  Print  |  Notify Moderator
I sure do LOVE my Bigfoot - serious 4 season trailer.
Rick ">
& wife Loie & Kodi Dog (blk male std poodle)
2011 GMC Sierra & 2005 25' Bigfoot RQ
camperbuds3
NE Pennsylvania
Posted: 08/03/07 06:36pm Link  |  Print  |  Notify Moderator
Not to get off the main topic, but someone mentioned low temperatures in the U.S.
Just a bit of trivia:
The lowest recorded temperature in the lower 48 states was at Rogers Pass, Montana -70F, -56.5C, January 20, 1954. Now that's cold weather!
2006 Sunline T-2075 TT
2009 F-150 XLT 4x4 SuperCab
smokestone52
Las Vegas, NV
Posted: 08/03/07 06:52pm Link  |  Print  |  Notify Moderator
I was born and raised in Idaho. I suspect that a travel trailer built for extreme temps will do. Artic Fox is a good one.
But, it depends on where you are staying. Boise, has what Idahoans call mild temps. No lower than -10 degrees at night. Central Idaho where I am from has recorded in the last ten years, -43 and just north in high country Idaho a record of -65. Even an Artic Fox would have you frozen hard as a rock in that extreme.
Let me know, and I can tell you all about winter in Idaho.
06 F-150 Lariat 4X4, 5.4, 3.73 rear. Reese WD, and sway. Pulling,
06 Pioneer, 180CK, with air.
Jet Dr.
Georgia
Posted: 08/03/07 07:26pm Link  |  Print  |  Notify Moderator
We have a 2005 Coachmen Captiva 288, and its great in cold weather. I know you thinking it doesn't get cold down here in Georgia, but it does, and it seems to be when we decide to go camping. Last cold trip, it got to 15 degrees and the camper did fine. Some of coachmen's and others too, have enclosed underbellies and heated air is ducted into this space to keep the holding tanks and plumbing from freezing. I did not know mine had that till I found the heater duct that did the heating. works great.
