KMLsquared
Rohnert Park, CA
I will and thanks
2002 HO 6spd LB QC 4x4. Edge Juice w/Att 4" str8 pipe AFE int Skyjacker D25 springs w/10" Fox Shox 2.0 Thuren track bar PSC Steering box w/DSS. Fox Steering Damper w/custom mount.
1993 Fleetwood Caribou 10HX
2001 Warrior
2002 Banshee
1969 Baja
jegssr
eustis, fl
There's not much wood there on ANY camper. I suggest that since yours is already weakened, that you traingulate the mounts by welding a one foot section of angle iron to each mount on the bottom front corner, and anothe one foot section to each mount on the bottom left(and right) corner. Drill holes through the angle into the frame. That will make your mounts three times a strong.
saved and blessed:)
One gorgeous wife since '67, '69 son, '71 daughter
'03 Cummins 4WD, '03 AF 1150, Generac, solar,
[b]'93 Lance 900, Onan TEMPORARILY!
truck, trailer, motorhome and sailboat camping since 1967.
Note: Due to invalid formatting, all formatting has been ignored.
KMLsquared
Rohnert Park, CA
jegssr wrote: There's not much wood there on ANY camper. I suggest that since yours is already weakened, that you traingulate the mounts by welding a one foot section of angle iron to each mount on the bottom front corner, and anothe one foot section to each mount on the bottom left(and right) corner. Drill holes through the angle into the frame. That will make your mounts three times a strong.
I do plan on adding metal where I can
KMLsquared
Rohnert Park, CA
Well I have removed some siding and did some digging. This is what I found.
I am almost positive the water came in from the jack mounts. I plan on using git-rot to stop the rot ans add some strength back. I have already cut out the really bad wood.
jegssr
eustis, fl
Git Rot or Smiths CPES (better) will definitely help the vertical member, but the horizontal wood needs replacement and reinforcement.
KMLsquared
Rohnert Park, CA
I removed the bad wood and soaked it CPES. I used liquid nails and screws to fasten the new wood. I also made some reinforcement brackets for both sides.
JoeChiOhki
Keizer, Oregon
That looks like chunks of oak ya got there! Nice fix up job.
Follow along with me at The Journey of the Redneck Express
CB Channel 17 Redneck Express
'1992 Dodge W-250 Power Wagon - Club Cab Long Bed V8 5.9L 4spd H.D Auto 4x4 4.10 Gears
'1987 Pullman Mini Camper
MasterBoondocker
nw lower Meeeechigan, TN and FL
WOW ... nice job so far. Can I bring mine over ?
KMLsquared
Rohnert Park, CA
Thanks for the kind words. So many times while tearing deeper and deeper into it I wondered if I would ever get it back together. Lots of help was provided by this site and its members. Wood is not my specialty, metal is more my speed. Last night I put one of my custom made jack mounts on and it feels super rock solid. On leg is now lagged into a 2x2 instead of the edge of a 1x4. The other leg is bolted clear thru to the metal reinfocement and super strong. I will post pictures when its daylight.
Sorry master i think one is enough for me.
