RV.Net Open Roads Forum: Around the Campfire: ceiling fan help please
Open Roads Forum  >  Around the Campfire
 > ceiling fan help please
grump daddy
Westland, MI
Posted: 08/22/07 01:02pm Link  |  Print  |  Notify Moderator
Are you using the wall switches just for on off or are you using the wall switch on the fan circuit to control the speed of the fan?
Shotgun
CA
Posted: 08/22/07 07:20pm Link  |  Print  |  Notify Moderator
when he installed the fan, did he take the shipping brake off the motor before installing the blades?
Hunting is not a hobby. It is much more life sustaining than that.
Dale-pilot, Jeanette-co-pilot
Electrician since 1978
2003 30' Sprinter 5er
2001 Dodge CTD
corkyb
Murrells Inlet, SC
Posted: 08/22/07 11:19pm Link  |  Print  |  Notify Moderator
It's almost like the common is open and you are completing the circuit via the copper ground wire. The problem may rest at your circuit panel where the fan circuit common is terminated to the main common block...
corky
wtb
idaho
Posted: 08/23/07 12:12am Link  |  Print  |  Notify Moderator
thanks everyone for the replies.
since neither he nor I know much about electricity, he has decided to have an electrician come look at it.
Gster
Massachusetts
Posted: 08/23/07 05:31am Link  |  Print  |  Notify Moderator
i am impressed with this reasoning.
i was gonna say: did you balance the blades
DKean
Mays Landing NJ.
Posted: 08/23/07 06:53am Link  |  Print  |  Notify Moderator
George.
Was your suggestion made from your experience .
baldag
Chattanooga Tn
Posted: 08/23/07 07:21am Link  |  Print  |  Notify Moderator
Donald, although I have received my share of "why did I do that" shocks, none have been with my tongue, although I did once get my tongue stuck to a frozen mailbox!
George
"I was cut out to be rich, but I got sewed up wrong"
2006 Dodge Ram 2500 QC Laramie 4x4 SB CTD auto "Buck"
Flagstaff 26RLS
Hensley Arrow
Prodigy BC
houtrz
Lake Jackson Texas
Posted: 08/23/07 08:58pm Link  |  Print  |  Notify Moderator
The motor brake or shipping break is usually a set of plastic pieces that are held in place by the screws that hold the fan blades on so by removing the screws, you must remove the shipping brake, at least in all the fans I"ve seen.
