RV.Net Open Roads Forum: Around the Campfire: ceiling fan help please
Open Roads Forum  >  Around the Campfire
 > ceiling fan help please
wtb
idaho
Posted: 08/21/07 07:57pm Link  |  Print  |  Notify Moderator
my nephew had a hampton bay brand ceiling fan (from home depot) that hummed and spun slowly on all three speed settings.
home depot replaced the fan with new one, which upon installation, does the very same thing!
the thing is, this same model fan in his sister's room accross the hallway works fine!
the fan is wired for seperate wall switches for the fan and the lights, and does not seem to be under-volting, that is, the lights don't dim when the fan is switched on, etc.
could we have overlooked something simple, or is possible to have gotten two bad fans in a row?
thanks for your help.
MasterBoondocker
nw lower Meeeechigan, TN and FL
Posted: 08/21/07 08:08pm Link  |  Print  |  Notify Moderator
what IS the voltage read ?
Mountain Jack
Shangri-La,Mountain in SW OR, above the Gold Creek
Posted: 08/21/07 08:10pm Link  |  Print  |  Notify Moderator
well...............i would use a voltage meter...........connect to the fan wiring................see if there is 120 volts............to start with.................
wtb
idaho
Posted: 08/21/07 08:31pm Link  |  Print  |  Notify Moderator
sorry, don't have a volt meter. the house is fairly new, and everything else seems to function properly.
jcapps
Not a senior just a
Posted: 08/21/07 08:32pm Link  |  Print  |  Notify Moderator
buy a voltmeter! cheapo is better than none $10 at Home Depot
"The great challenge of adulthood is holding on to your idealism after you lose your innocence."
– Bruce Springsteen
"This ain't the practice round"
- a friend
baldag
Chattanooga Tn
Posted: 08/21/07 08:44pm Link  |  Print  |  Notify Moderator
Expose the wiring and touch your tongue to it. If it knocks you on your arse, the voltage is sufficient!
DISCLAIMER: this response is intended as humor, and as such is exempt from poofing...
George
"I was cut out to be rich, but I got sewed up wrong"
2006 Dodge Ram 2500 QC Laramie 4x4 SB CTD auto "Buck"
Flagstaff 26RLS
Hensley Arrow
Prodigy BC
Mountain Jack
Posted: 08/21/07 08:51pm Link  |  Print  |  Notify Moderator
George
wtb
idaho
Posted: 08/21/07 08:55pm Link  |  Print  |  Notify Moderator
thanks george. I already suggested that to by brother in law, but I think he's going to call an electrician instead.
seriously though, I am so impressed with the info and willingness to help on this forum that I tend to come here first for help with about anything.
guess I was just hoping for a simple "you must have crossed the green wire with the flux capacitor" type of thing.
anyway, thanks to all for your time.
donsm60
Posted: 08/21/07 09:00pm Link  |  Print  |  Notify Moderator
Along with the 'tongue method' you could always use the 'testicle method' If it hurts really bad the power is fine. Sorry, just messing around
I'd be testing the line and everything on the circuit with a volt/amp meter as a start. Good luck
Kajtek1
CA
Posted: 08/21/07 09:18pm Link  |  Print  |  Notify Moderator
My first guess would be, that the fan motor and lights are wired in the row.
Than it might be wires pushed into the rotor,or factory defect.
Pessimist sees dark tunnel, optimist sees a light at the end, realist sees lights of coming train.Engineer sees 3 idiots on the tracks.
