RV.Net Open Roads Forum: Hybrid Travel Trailers: How to get Hitch Weight
Open Roads Forum  >  Hybrid Travel Trailers
 > How to get Hitch Weight
Kentucky Steve
Crestwood, Ky
Posted: 08/24/07 07:01pm Link  |  Print  |  Notify Moderator
Just a quick question, what is the best way to get your Hitch Weight? Do you have to use a public scale, or can you buy a tongue weight scale?
I've read where you can use a bathroom scale, but these never seem to be anywhere accurate.
Thanks in advance for the info!
Chuck&Gail
In the Colorado Mountains
Posted: 08/24/07 07:10pm Link  |  Print  |  Notify Moderator
Can't see why bathroom scale would be inaccurate if done properly. Works fine for us.
Actually you can probably use your bathroom scale if you know the trick. Suppose you maximum tongue weight is 1000# and your scale only reads to 200#. What you need then is a 5 to 1 multiplier.
You will need two pieces of strong metal pipe (2" is good), several blocks (leveler blocks work fine), a 2x12, say 6 feet long (more on this later), and two 12x12" pieces of 2x12. Take two pieces of 2x12 and cut a Vee groove in each of them. Cut a Vee groove near each end of the long 2x12, parallel to end, 6" from end. Note grooves are exactly 5 feet apart, this distance is IMPORTANT
Put small 2x12 block on top of scale. Put piece of pipe in groove. Put 6' 2x12 groove on pipe.
On other end of 6' 2x12, put the other small block under it, with pipe in between. Next note that long board is not level because the scale adds height on one end. Put blocks, equivalent to the scale height, under the low end (end without scale).
You should now have a 2x12 supported by blocks on one end, able to pivot on a pipe between two Vee grooves, five feet apart. On the other end is a similar arrangement set on a bathroom scale (make sure you can read the scale). Now zero the scale so the board weights are removed.
Note if you now stand in the exact center of the 6' 2x12, the scale will read HALF your weight.
If you stand 1 feet from the pipe pivot, away from the scale end, it will read ONE FIFTH of your weight.
Your bathroom scale can read 200#, and you just built a 5 to 1 multiplier. Put the tongue jack 1 foot from the non scale pipe end (1 1/2 foot from end of board). Since the board is five feet between pivots, the scale will read one fifth of the load. Note TT should be level front to back for reading to be accurate, so adjust tongue jack as needed.
Have fun, and if this does not make sense or I missed a step, send me another private message.
Yes there is a slight error by using the tongue jack instead of the receiver, but it is small.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
trails2004
Wyoming
Posted: 08/24/07 07:41pm Link  |  Print  |  Notify Moderator
huh?
2002 Dodge Ram 2500 SLT 4x4-AFE Cold Air,4"Exhaust,Toyos,Ranchos,Dual Air III- Firestones 2004 Hallmark Cuchara XL 9.5 w/Carbon Fiber Roof, WFCO 9845,Xantrex XBM,Honda 2000,1997 Grumman GV19TC- Crew Wifey,(Odin,Bridger & Sam,Wirehairs)
alpenliter
Olympia WA
Posted: 08/24/07 08:27pm Link  |  Print  |  Notify Moderator
Or you can invest in one of these: Sherline Hitch Scale. Type into search engine.
2004 F-450 CC, DRW 6.0 Classy Chassis
1997 33' Alpenlite St. Andrews
Lifetime Good Sam Member #39644174
Escapees SKP#89882
Alpenlite Travel Club #5955
Vietnam Vet '67-'68
Extreme Makeover RV Style! Click here!
Kentucky Steve
Crestwood, Ky
Posted: 08/24/07 08:45pm Link  |  Print  |  Notify Moderator
THANK YOU so much, I just ordered one!
Chuck_S
Broadview Hts, OH, USA
Posted: 08/25/07 04:44am Link  |  Print  |  Notify Moderator
While many of us are initially concerned with overweights, not enough weight on the ball is the cause of fishtailing (usually called sway):
Jayco 23B is tongue-light and, consequently needs sway control.
-- Chuck
'06 Roo 23SS behind '07 Expedition out of Cleveland
Our Photo pages
miserytom
jacksonville, NC
Posted: 08/25/07 02:14pm Link  |  Print  |  Notify Moderator
the average hitch weight is about 10-12 % of the trailer total weight, you can use that as a rule of thumb also
Tom, DirecTV Field Tech
03 flagstaff shamrock 232
06 GMC Sierra 1500
Camper Pics
