RV.Net Open Roads Forum: Tech Issues: Mineral oil in batteries
 > Mineral oil in batteries
Page of 5
bill h
el segundo
Posted: 09/12/07 10:40pm Link  |  Quote  |  Print  |  Notify Moderator
As a kid in NW Iowa, I walked RR tracks to hunt pheasants in the ditches on each side. Found a whole lot of those bottles. Wisht Ida saved em.
Bill and Susan
84 Barth 30 tag powered by ht502/Thorley, Gear Vendors OD
Siamese Calvin and Airedale Hobbes
4WD Toyota toad
donandmax
Delta Co.
Posted: 09/13/07 09:17am Link  |  Quote  |  Print  |  Notify Moderator
Went to Camping World web site. Could not find oob anywhere. Nor "battery oil" of any kind.
bill h
el segundo
Posted: 09/13/07 11:57am Link  |  Quote  |  Print  |  Notify Moderator
Yeah, they kinda fell off the market. One poster here has a relative who is a chemist, and just plain mineral oil was said to do the job. My own non-chemist take on it is that the floating layer of oil, being thick, acts as a mechanical splash reducer and evaporation preventer. No chemistry, no magic, just simple physics.
If I ever end up with an extra motorcycle battery, I will cut the top off or two cells, and put a little oil in one and charge until gassing occurs. The difference should be readily seen. I know my batts use less water and are cleaner since I started using mineral oil in the seventies. Chargers have gotten better since then, with less overcharging being the result, so the benefits of oil are not as dramatic as before. But the final stage of charging still produces hydrogen gas, which bubbles and splashes.
gon2dadawgs
I'm here X
Posted: 09/13/07 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
At work there are numerous sites with UPS systems and an oil is used in those batteries. Here is a site that may help the skeptical. I use oil in mine and they are doing fine.
Battery oil
Michael
Home is where you unhitch
Deen
Vancouver, WA
Posted: 09/13/07 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
hwybnb wrote:
No, I do not - as applied to modern automotive system maintenance. If it is a valid concept it would be endorsed, or at least mentioned, by today's battery manufacturers.
My experience and others says it IS valid.
* This post was edited 09/13/07 07:16pm by Deen *
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'08 Honda Civic/dolly
'05 Honda Odyssey/dolly
NRA Benefactor Life Member
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
51st yr of RV'ing
gon2dadawgs
I'm here X
Posted: 09/13/07 03:19pm Link  |  Quote  |  Print  |  Notify Moderator
Deen wrote:
hwybnb wrote:
bill h wrote:
Do you consider Thomas Edison a credible source?
Some concepts, put into practice, never change. The wheel is a decent example.....is the inventor of the wheel credible to you?
If you own a business, say EXIDE battery, would you want us to know of a product that would lessen your profits?
Michael
Briteskys
Mesa, AZ
Posted: 09/13/07 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
My sister-in-laws ex husbands brother says to use Marvel Mystery Oil in batteries.
'02 Beaver 40' Patriot Thunder
CAT C12 455hp
Jeep Grand Cherokee
Ron & Jane 2007 - 08
Ray,IN
IN, USA
Posted: 09/13/07 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
original reply deleted. See Thermoil website. OOB is the Thermoil "old" formula, which actually reduced battery life, per website.
* This post was last edited 09/13/07 08:35pm by Ray,IN *   View edit history
ed6713
FL
Posted: 09/13/07 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
I've used snake oil in my batteries for years. My Model A still starts on the first try after all these years.
Have some for sale if you need any.
Deen
Vancouver, WA
Posted: 09/13/07 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
Lots of nay sayers that have NEVER tried it, I have. It works. So I will CONTINUE to use it.
Page of 5
