Dan4fish
Wake Forest N.C
I just up gaded from an 2003 f250 psd 4by4 to a 2006 f350 psd drw 4by4
I hav a 2007 arctic fox 811 do you all think I will still need air bags with the new truck? or is there a better option that is cheaper than airbags?
Dieselgem
Northeast
Check out Timbrens they may work for you.Timbrens
08-KZ Escalade 41'CKS Escalade
2008 F450 Super Duty Truck
2003 FLSTS
2003 FLSTC (Wife's)
work2much
Jackson Ca
I would try with just the factory springs and go from there. Looks like that camper is probably around 4k wet and ready which is probably right around the trucks rating. The one nice thing about air bags especially with campers that have a slide and are usually heavier on one side is the ability to level the truck by having unequal amounts of air in the bags.
Greg
"Never argue with an fool, they will only bring you down to their level and beat you with experience"
2004 Dodoge 3500 SLT 4X4 6 speed
2006 Arctic Fox 1150 dry bath
2003 Bigfoot 10.6
2006 Harley Road Glide
Dan4fish
Wake Forest N.C
I am going to try it first before I do any thing I hope I don't have to make any changes. I am looking foward to the added stablelty of the duel rear wheel
Steve_in_29
29 Palms (SEMPER FI), CA 92277
Try the camper without the bags first and see how it works. Ford upgraded the load capacity in 2005. Even on my previous 2004 truck it would support my 3000ish lb camper without any suspension add-ons (it did have the camper and snow plow prep packages though). My 2007 doesn't even sag to level.
2007 F350,SC,LB,4x4,6.0/Auto,35" tires,16.5 Warn,Buckstop bumpers
2007 Outfitter Apex9.5,270W solar,SolarBoost2000e,2 H2K's,2KW inverter,2 20lb LP on slide out tray,4 Lifeline AGM bats,Tundra fridge
95 Bounder 28' ClassA sold
91 Jamboree 21' ClassC sold
bradt
Chicago, IL
I have a 2006 F-350 DRW PSD 4X4 with a 2005 Lance 981 (has slide as well). My camper is probably a bit heavier. I tried with the stock suspension and was shocked at how much the truck squatted with the camper loaded. I added a set of Timbrens a month ago and couldn't be happier. The truck is comfortable unloaded and rides level just barely touching the factory overload springs when loaded.
I've heard a lot of people commenting about the jarring that happens when the truck goes over tracks or a speed bump. This was my only cause for hessitation when buying the Timbrens. I have paid attention and have noticed absolutely *no* difference in ride quality.
Just my thoughts. Good luck with the new truck. I know I love mine.
Brad T.
2006 F-350 Lariat PSD DRW CC LB w/ Timbrens
2005 Lance 981
Dan4fish
Wake Forest N.C
bradt how much does your camper weigh? mine is supposed to be 3100 wet
davedye
New Columbia, Pa. 17856
I have a Lance 845 on my 3500 Dodge, it ways 3400 ready to camp. It just makes the truck level. No modifications. I also pull a 3000lb boat, still level.
Dave
2006 Dodge Ram Dually, 3500 Quad Cab 4X4, 4.10 Gears, Cummins Diesel
2008 Lance 981 Max, Torklifts, Class V Reese Tow Beast with 24" extension, Torklift Stable Loads
2005 Triton DV 176 DV w/150hp Mercury Optimax
bradt
Chicago, IL
oh, there's quite a difference in weights between our two campers. Mine is supposed to be just over 4,000 wet.
Troutguy
Brandon Twp. MI, USA
Dan4fish wrote: bradt how much does your camper weigh? mine is supposed to be 3100 wet
Hi,
Don't mean to jump in on your question to bradt but I bought a new A.F. 811S in mid July and on my way home from the dealer I stopped at a local CAT scale and had it weighed.......Over 3,300 lbs. completely empty with both propane tanks filled, no other fluids, and nothing else in the camper...just the way that it came from Northwood. Also no AC or generator.
This is a very heavy camper...don't be fooled by the fact that it's just a 9' camper. The factory sticker weight is 3353 lbs; so the actual vs. sticker weight is very close.
Hope this helps.
TG
2001 Red Chevy 2500HD X-Cab SB D-Max/Ally 4x4
2006 Arctic Fox 811S Truck Camper & Honda EU2000
2008 Suzuki DL650 V-Strom motorcycle
