crosbygroup
california
I have a new Carrier 13.5 AC unit on my PUP. I would like to run the AC when BD. I do not need to run other things while running the AC. I have read some posts that say the Yamaha 2400 will run the AC and some that say the Yamaha 2400 won't run the Carrier AC.
The folks at Wisesales say the Yamaha was built for rv use and it should be fine. Yamaha is a little smaller and a lot lighter 70lbs it costs $1139. The Honda is only a 5 inches longer, 2 inches winder and 4 inches taller, but weighs 135 lbs. it costs $1699. The Honda should be quieter, it has a larger tank so the run time is longer and has an electric start.
Any recommendations?
Thanks.
Crosbygroup 2008 Fleetwood Avalon Highlander
If you're not part of the solution, you're part of the precipitate. ~Henry J. Tillman
bushman512003
wallaceburg,ontario,canada
I like the Honda Myself 600 more watt's I run the hole Motor Home on it and that's on eco.mode.I like that and the elec.start is also a great idea plus more fuel for less filling it seem's good on gas and the weight is more but I think a better over all unit MHO...well worth it I did look at both when I bought mine.3 years ago and nothing but gas and oil changes I also have syn.oil since break in 3rd change...Bushman
Forest River Reflection,Cummins pusher,slide out,and all the toys.Enjoying camping,friends, fire. LOL. life is good..John,Jeannette,and Molly the little Camping Ferret...From Canada the Queen's Country..Member of IRV2.Com. The Bushman EH!
cabanaman
middleburg florida
If you got the money the honda will give you power to spare.With the yamaha if you have the A/C on that will be about it.I'm kinda cheap so I would get the yamaha and budget out the power.
Retired Navy
2007.5 Dodge Ram SLT sport 2500 quad cab 6.7 cummins,6 speed auto with exhaust brake.EGR removed,DPF delete on order,hypertech econ program B.
2007 Open Road 378SA4S-5 quad slide.
2manytoyz
Central FL
... and now from someone who owns a Yamaha EF2400iS...
Here's the testing I've done: Link.
I've talked with a LOT of people who've read my article, bought one themselves, successfully ran their own A/C unit, and thanked me for the info.
To date, I've only talked with one person that had real issues running his A/C. As it turns out, he had a 15,000 BTU A/C unit. Too big I thought. He was able to run it, but when it cycled, it overloaded the generator and it dropped out. He'll need a much larger generator, likely well over 3KW.
I've been able to easily run my 13,500 BTU A/C unit, my converter/charger, lights, TV, stereo, and refrigerator, with power to spare.
FWIW, the Yamaha EF2400iS uses the same sized motor as the 2800 Watt, and 3000 Watt Yamaha generators. It also has been tested to carry a 3000 Watt surge (25 Amps for 10 seconds according to Hayes Equipment).
It's half the weight of a quiet series 3000 Watt Honda or Yamaha. It's less expensive.
I don't know why you'd think the Honda would be quieter. At full load, the Yamaha is rated at 58 dB. Mine runs at about 2/3rds throttle (subjective ear measurement) running everything in my camper, except the water heater and microwave. So mine is somewhere around 55-56 dB??? Bottom line, it's so quiet, I can't hear it from inside the camper, and barely from the opposite side of the camper when outside.
Have you picked up a 3000 Watt generator? If you decide a 2400 isn't enough, then I would recommend getting 2 Honda 2KWs and a parallel cable. At least your back will thank you.
Robert
Cocoa, FL
2007 Rockwood TT 2502
Equalizer Hitch
Prodigy Brake Controller
2005 Nissan Xterra
2006 Jeep Wrangler Unlimited
Yamaha EF2400iS
crosbygroup
california
Thanks, I'm leaning toward the Honda eu 3000. I'm sure it will run the AC. I'm concerned about running my Carrier 13.5 AC. I have seen other posts that say the Yamaha 2400 won't run the Carrier.
javaseuf
Southern Cal
Just went through this today. The 2400 would NOT run my friends new Carrier 13.5. He is selling the 2400 and getting a Yamaha 3000 w/boost.
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
crosbygroup
california
javaseuf wrote: Just went through this today. The 2400 would NOT run my friends new Carrier 13.5. He is selling the 2400 and getting a Yamaha 3000 w/boost.
Why the Yamaha 3000 with boost instead of Honda EU 3000?
javaseuf
Southern Cal
I hvae the Yamaha 3000/boost. I liked the Boost feature and, to be quite honest, I liked the looks better than the square Honda. I am sure I would have liked the Honda just as well.
edited 09/07/07 12:47am by javaseuf *
jkmcgrath
Midwest
I have a Carrier AirV 13.5 brand new, less than 2 hours on the A/C unit.
Start up Amps are 17.9 for mine (2142.63 watts 119.7v)
Hi Cool run amps were 13.26 and climbing slowly as it ran (1587.22w 119.7v)
This was at 83* elevation 1292'
Yours maybe more or less.
2005 F350 Lariat 6.0 PSD CC DRW
A.R.E Impulse TW
Class 5 Reciever
Equalizer WD
2007 Haulmark 28' Edge
Carrier AirV 13.5
2006 (19 June) Kipor KGE3000TI 2800/3000w
Twin Honda EU2000Is
Nuvi 360 USB 18 & 76S
Sierra Wireless AirCard 875
chevylover1965
Southern CA
I own a Yamaha 2800i. It has no problem running a 13.5 AC unit and only weighs in at 65 lbs.
05 Fleetwood Expedition 37U
CAT C7
08 Honda CRV EXL/NAV
Roadmaster Falcon All Terrain tow bar/US Gear
FBINA 144
