RV.Net Open Roads Forum: General RVing Issues: Have you seen this one?
 > Have you seen this one?
Kentucky Steve
Crestwood, Ky
Posted: 09/03/07 04:49pm Link  |  Print  |  Notify Moderator
I need some help on this one. My DW poured the dishwater down our toilet to get more water in the black tank for dumping. However, when she dumped it, a fork was still in the water, and went right down the toilet into the tank. It did not come out when we dumped. Do you think we will have a problem "down the road"? Or will it just lay on the bottom of the tank? HELP from a somewhat newbie.
Polishnurse
Schodack, NY
Posted: 09/03/07 04:58pm Link  |  Print  |  Notify Moderator
The only problem you might have, should it decide to move, would be hanging up cross ways in the tank, and causing a stoppage as paper and what have you wrap around it.
You can remove the toilet without to much trouble, and reach down in side and feel around for it, of course you should dump the tank first and wash it down with some clean water first. Rubber gloves might also be an option. I wouldn't want it down there in my tank. JMHO Bill
352
Oxfofd, Fl
Posted: 09/03/07 04:59pm Link  |  Print  |  Notify Moderator
reach your arm down as far as you can and see if you can feel it.good luk
1937(BAD BOY)pontiac,all steel,chevy 350,dyno=405hp,650 holley double pumper,ps,pb tilt wheel,heat & air,
700 r4 tranny,headers,3" exhaust with flowmasters.
just a good ole southern redneck country boy.our favorite place to go to swim with the manatees
davidj54
South Alabama
Posted: 09/03/07 05:04pm Link  |  Print  |  Notify Moderator
It's hard to say if it'll be a problem down the road. I suspect that it won't and one day when you're flushing it'll come out. If anything,it may turn crosswise of the outlet and catch some paper. As insurance I would get a back flushing device (Flush King, Dual flush Pro, etc.) so that if that happened you could back flush to get it to move or turn. I wouldn't spend time worrying about it just be ready if it does happen.
Dodge Ram 2500 Mega Cab (Yeah, it's got a Cummins)
2006 Forest River Grand Surveyor GS-280
Prodigy Brake Controller
1000/10000lb Equal-i-zer with 4-way sway control
Rick and Toni
MO
Posted: 09/03/07 05:07pm Link  |  Print  |  Notify Moderator
DH and I were discussing your problem and feel it could be a definite problem. Drain the tank, turn off the water, get a light and see if you can see the fork by looking down the toilet. If a magnet will attach to your silverware maybe you could try rigging up something to lower a magnet into the tank and pull it out that way. Something else to try would be one of the grabbers that people use to pick things up. I don't know if one of those would fit down the toilet. Good luck. Toni
Rick and Toni
2004 Coachmen Sportscoach Limited Edition
1 Westie
Horsedoc
Dixie --- N. Georgia
Posted: 09/03/07 05:35pm Link  |  Print  |  Notify Moderator
*NOTE TO SELF* If Ky Steve recovers the fork, don't go to dinner if he invites you!
Dozer Don
LA, Calif.
Posted: 09/03/07 05:40pm Link  |  Print  |  Notify Moderator
A magnet will only work on certain metals. Was it sterling silver, aluminium, or stainless steel?
01 F350 PSD, 2003 Alpenlite Augusta 32ft 5th Wheel.
BD Exh. Brake, Aux. Trans. Cooler, Exh,Boost&Tr. Gauges.
Mag-Hytech Tranny & Diff.covers. 1 Chocolate Lab. 2 Honda 2000e's
sflabrkr
florida
Posted: 09/03/07 05:44pm Link  |  Print  |  Notify Moderator
Take the toilet off and use a magnet. after removal of fork note which one it is and mark it company only
dbbls
Missouri
Posted: 09/03/07 05:51pm Link  |  Print  |  Notify Moderator
It could be a potential problem. If it is a set of 4 than you and your wife could only have one guest for dinner. Now if it is a set of 8 you would be better off. This would allow five guest, probably more than your RV could handle. Now, if your are eating outside, use plastic ware.
1999 F250 Superduty, V10 with Banks Power Pack
2004 Colorado 29RL 5th wheel with 3600 watt Onan
Wherever I happen to park
Posted: 09/03/07 06:20pm Link  |  Print  |  Notify Moderator
Yes, you could fish for it with a magnet.
My feeling is it will.. Some day.... Exit the tank and possibly lodge in the elbow at the end of the hose where you can easily remove it with a gloved hand.
But... Other things might happen too.
