RV.Net Open Roads Forum: Alternate "portals" to the RV.net Open Roads Forums
RV.net
Search only in Forum Technical Support
Open Roads Forum  >  Forum Technical Support
 > Alternate "portals" to the RV.net Open Roads Forums
RVSnowbird
OR-NV-AZ-OR
Posted: 09/08/07 11:58am Link  |  Print  |  Notify Moderator
Affinity Group Inc. (AGI) is made up of several recreational vehicle domains. Many offer a forum which are all in one that we call the "RV.net/Forum".
Think of it as a wagon wheel and any one of the following "spokes" or portals will get you to the center point or www.rv.net/forum as the "hub". The only difference between them will be the logo at the top left of each portal page as shown above.
www.RV.net/forum
www.Woodalls.com/cforum
www.TrailerLife.com/forums (1024x768 or variable width setting recommended)
www.TLDirectory.com/cforum
www.OpenRoadsForum.com/forum
www.CoastResorts.com/cforum
http://www.goodsamclub.com/forums/default.aspx
www.MotorhomeMagazine.com/cforum (1024x768 or variable width setting recommended)
Click on one of the portals above, sign in and go to your "My Forums". Once there, click Favorites on your browser to save it as an alternate. This is especially wise where there are server problems as one or more portals may be still working when another is down.
All website portals are optomized at 800x600 monitor resolution except as indicated above. If you have a problem with the display, click on your My Forums at the top right and then your My Preferences on the left in the upper links bar. Sign in with your password and check the Page width settings. You have choices of:
Variable Width
Fixed Width (800x600 resolution)
Fixed Width (1024x768 resolution
Check over the rest of your preferences and when done, click on Submit Changes at the bottom of the page.
* This post was last edited 07/14/08 09:32am by an administrator/moderator *   View edit history
