Oakman
MO
I was wondering if anyone knew if I would be encountering very many long steep uphill grades from Sante Fe to Colorado Springs.
Any info is appreciated.
2002 Dodge 2500 V10
2008 Wildcat 28RKBS
Honda 2000 gen
TomTom One 3rd edition GPS
LA-REDNECK
GRAND BAY.AL, USA
I ran it from northern Wyoming (Orin) down thru Cheyenne and Denver. Had no problems pulling my 36 ft 5th wheel with 2500HD Duramax GMC. Most are long and should give you no problems. (August 2007)
LA-REDNECK
2002 GMC Duramax
2004 Jayco Designer Legacy
NGRRFan
Colo. Spgs., CO
IIRC.... Once you leave Santa Fe it's fairly "level" until Raton and then you go over Raton Pass.
Then there's a couple of "uppy-downs" before you hit Pueblo but nothing to be concerned about.
Rich,and Tobi (the rescued dog)
Prowler 5ver, 84 Ford F250
KCOCOLOR78 Weather
Colo. Spgs. CO
cruiserjs
Aurora, CO, USA/ Mesa AZ/ openroad
NGRRfan should have also said that Raton Pass (CO/NM border) is not a very steep nor very long pull. One of the easiest in all of CO mountain country. WE travel that section of I25 almost every spring in our migration from AZ to CO. and reverse in the fall (October is fast approaching!!
John
Colorado Cruiser
Cruiser CF29CK 5th wheel; 2001 Silverado 2500HD shortbed
wonderful lifetime travelling companion/spouse
Oakman
MO
Thanks for the responses. I was hoping I wouldn't encounter the same type of grades on I-25 that we had on I-70 in Colorado. Those grades on I-70 are brutal on equipment.
SilnJohn
Denver
Heading north on 25 just before you get to the Rye/Colorado City cutoff, There is a fairly steep down hill grade (probably 5%) with a sharp left curve. I grew up near that area and it sneeks up on people. Seen many semi's and RV's roll there. If I remember right its around mile marker 70.
kennethwooster
Perryton Tx USA
We travel from Raton to Colorado Springs a lot. We're pulling a 38' 5th and never had any problems. Just like everybody said Raton pass is the only steep one and its not bad.
kenneth wooster- farmer
wife Diana-adult probation officer
365BSQS Quad slide 2007 Quantum
Ford F350 2005 model, 4X4 FX, King Ranch
18K SuperGlide Hitch
