RV.Net Open Roads Forum: General RVing Issues: REPORT YOUR TIRE -FAILURES- HERE -
 > REPORT YOUR TIRE -FAILURES- HERE -
Page of 6
ol Bombero-JC
Posted: 09/12/07 11:49am Link  |  Print  |  Notify Moderator
Interesting thread on -General RVing Issues- forum:
"Mission Tires Suck" - along with lots of other (brand) failure stories.
bigdodgeram
southern Calif.
Posted: 09/12/07 03:13pm Link  |  Print  |  Notify Moderator
could you all post how many tires?
as of this post the following sizes are affected.
st 235/85R16
st 235/80R16 - 3 posts
lt 235/85R16
st 225/75R15
XPS in above size seem to be OK.
all above tires are on LARGE RV's meaning around 10,000 pounds.
what does this mean?
95,Dodge RAM 2500 Club Cab, Red, SLT Laramie 2WD, 5.9 V-8, 46RH Trany. 5th Wheel Hitch & Tailgate. Tekonsha Prodigy brake controller. 1998 Fleetwood 28' Wilderness 5th wheel, 2 legged hitch support.
lovely wife, & Molly & Cassie our black & yellow labs.
byrdr1
Elon, NC / Central Piedmont
Posted: 09/12/07 03:50pm Link  |  Print  |  Notify Moderator
Mission Tires Load range "D" ST225/75R15
Right at 2 years old maybe 3000+- miles on them.
checked air night before trip noticed something odd when I set up camp 300 miles away.
blew out one tire within 20 miles of campsite on return trip home.
went to replace two and found 3 of 4 bad with thread separation on two unblown up ones. Lucky to have gotten home with out another blow out. Tire Dealer said real lucky.
On a 2006 Keystone Cougar 301BHS TT, CAT scaled at 8400lbs.
ol Bombero-JC
Posted: 09/12/07 05:51pm Link  |  Print  |  Notify Moderator
bigdodgeram -
Try a "Tires" search on the Travel Trailer Forum.
Usually (mostly?) lighter trailers - ALSO reporting failures, re-calls, etc.
Think the tire sizes you have seen here (previously) is because this
thread was (only) on the 5th wheel forum.
[Those are sizes commonly found on 5ers]
IMO - failures have nothing to do with size -
-ALL- to do with "country of origin" [where mfg].
JC
***Edited to reflect the requested move to General RVing Issues
* This post was edited 09/13/07 05:14pm by ol Bombero-JC *
azjeffh
Chandler, AZ
Posted: 09/12/07 07:15pm Link  |  Print  |  Notify Moderator
Sidewall cracking on 18 month old 15" Maxxis tires. Total 5er weight-10,170 lbs. Guesstimated milage- 8k.
Jeff
Wonderful wife Robin, no children, no pets, no money
05 F250 Supercab SB PSD w/Tow Command
05 HR Savoy 29RKS
Ford Man
Tennessee
Posted: 09/12/07 07:41pm Link  |  Print  |  Notify Moderator
My Mission Tires blew out in the first 500 miles or so. During the first trip. The Dealer, Keystone, or Mission tires would not do anything about it. This stinks!!
sirdrakejr
Las Vegas, Nevada
Posted: 09/12/07 11:09pm Link  |  Print  |  Notify Moderator
Moved from 5th wheels to Gen'l RVing Issues.
Frank
RV.net blog
For those of you looking for expert advice, here ya go!
Frank
Deen
Vancouver, WA
Posted: 09/13/07 02:17pm Link  |  Print  |  Notify Moderator
Been running Michelins on almost everything I own, never had a blowout yet. The fronts on the MH have run over 29,000 miles and are running an overweight condition according to Michelins chart by about 1000#'s on the rt front.
Did have a blowout on a GoodYear on the Jeep, 245/70 X 15. Don't remember which model it was.
Deen - Vancouver, WA
'02 Dutch Star 4090 (41+', triple slide)
435/1200 ISC Cummins/Banks PowerPak
'08 Honda Civic/dolly
'05 Honda Odyssey/dolly
NRA Benefactor Life Member
FMCA f47302s, Life Member: Good Sam,
Newmar DP Owners Group
51st yr of RV'ing
Flouncer
Loomis, Ca
Posted: 09/14/07 06:03pm Link  |  Print  |  Notify Moderator
Carlisle/Ameri*trailer x3
205/75/15
DOM Dec 2003 and May 2004.
2 Ameri Tariler, 1 Carlisle in last 6 weeks, 400 miles
<5,000 miles on tires
Came new with trailer, purchased new 6/2004
After 2nd Blow, checked with new gauge, 48 psi "warm", 3rd tire blew within 15 miles.
Weight on cert scale, 4640 lbs, and < 1200 lbs per tire, load distributing hitch
Tires rated for 1782 lbs per sideall, "Load Rande C"
Made In China (Carlisle) and USA (Ameri Trailer).
Both are Carlisle Tires
Claim for tires and damage to trailer in process with Carlisle.
HTW
( my $0.02 Tires that sit on ground, loaded, will fail due to belt separation as they flex and stress due to constant load on one spot. If you dont drive at least every 2 weeks, jack and raise your rig off the ground, tires off the ground or the tires will fail. It doesn't matter what brand, where made. Sitting equals death. My experience)
ol Bombero-JC
Posted: 09/15/07 09:18pm Link  |  Print  |  Notify Moderator
Tire "problems" are back on 5th wheel forum (again),
as well as on TT & MH forums.
Page of 6
