2008 F350 DRW Lariat 4x4 long bed 6.4 PS.
Truck max GVRW is 13,000 lbs. Total GCVW 23,500
Truck with fuel and 2 people. 5340 front
4240 rear
Total unloaded truck 9,580 lbs.
2006 Everest 323P Rear Kitchen Gross vech. weight is 14,200 lbs.
Front Axle 4,800
Rear Axle 5,260
Total Trailer Axle weights 10,060
Total weight of Trailer and Truck with full Propane and 20 gallons of water is 22,680 lbs. Under GCVW by 820 lbs.
10,060 axle plus hitch 3,040 is 13,100 lbs total trailer weight.
20% of 13,100 is 2,620 suggested hitch weight. I'm under everywhere except hitch weight, where I am over by 420 lbs. My total truck
GVRW is 12,620, under by 380 lbs.
I'm legal, a little tongue heavy, but very little wiggle room.
Truck pulls it nicely, but I have some of that Rear Kitchen bounce.
I'm reluctant to move any weight from the front of the trailer to the middle or worse back of the trailer.
Guess I just need to get rid of some junk in the basement!
Vehicle w trailer 9,200 / 9,580
Vehicle w/o trailer / 7,240
Max Load as noted 2,655 / 2,340
on door piller sticker
Trailer Axle / 8,520
Combined 20,000 / 18,100
From someplace in SE Wisconsin
2006 Silverado 2500 Ext-cab / reg box / D/A
2006 Jayco Eagle 325BHS
2001 Goldwing, Cyclemate trailer and a tent (to remind me why we have the Jayco)
1999 BMW 1200C (007 bike) too cool to part with
5ver 2008 Rage'n Xtra-Lite 3205 32' Toyhauler
100 gal water
40 Gray
40 Black
14 g propane
4.0 Onan
20 Gal fuel cell
UVW - 8310 lbs (includes propane and generator etc...)
Cat scale TV w/17 gal fuel and hitch 6060 lbs w/5ver on hitch 7580 lbs for a pin weight of 1520 lbs
5ver 15 gal fuel, food, clothes mountain bikes empty Fresh/Gray and Black tanks - 8400 lbs
Front trailer axle 3180 lbs
Rear trailer axle 3700 lbs
CGVWR 14,460 lbs
w/100 gal fresh water and 2 dirt bikes 9710 lbs
CGVWR 15,770 lbs
I couldn't believe a max tow rating of 8300 lbs for the 2000 model year 1 ton. I talked with GMC, the local guru on towing, and anybody else that's had an opinion on this and my goal became to stay under 10K. Not only for the license, but the truck actually performs well stock.
I am adding a tranny cooler, K&N filter and Magna Flow exhaust. I expect to pick up another 30hp and 11 ft-lbs of torque.
As everyone told me I wouldn't win any races, and I have more than enough truck, but I can pull Cajon Pass in So Cal at 55 mph (the speed limit) with no less than 35 mph at the steepest grade near the top at 2500 rpm. I could most certainly run it to the floor and maintain 55 bottom to top, but what's the point.
I'm getting 8 mpg with trailer and about 12-13 mpg without.
I'm sure there's a few here with opinions that have loads of experience, so please jump in!
I'm glad I found this place because all of my homework was by myself, and so far I think I did it right.
2001 Ford F-250 4x2/Extended Cab Short Bed/Lariat/6.8 V10
Truck w/full tank of fuel
6800 lbs
Truck with 2001 KZ Sportsmen 2457, full tank of fuel in truck, full LP in trailer, empty water/waste tanks:
15,000 lbs
Trailer works out to be 8200 lbs and gross is 10,000
Unfortunately, I did not have the axles positioned right to get all the axle weights, I have steer and trailer axles and gross.
Every axle is within specs, however my GCWR is exceeded by just over a ton. If my truck had the 8.1 gasser or the Duramax, it would have a 22,000 GCWR. So, brakes and frame are the same as the more powerful engines, I'll just climb the hills a tad slower. Pickup alone weigh 3540 on the steer, and 2940 on the drive axle, giving me a trailer weight of 11,560 and a pin weight of 2440. Montana says this trailer will have a hitch weight of 1770, I suppose that could be possible empty....Brochure gives trailer GVWR as 11,930 but sticker on the side of the camper says 12,105 for a GVWR. Tires are ST235/80R16 Load Range E with a load rating of 3560 per tire. The truck rides very nice and level with the stock suspension. Brochure also says the trailer weighs 9690 dry, so I have added 1870 pounds of water, propane, clothes, food, blocks, beer, etc.
It is my observation that virtually all of the Chevy Duramax's 6.6 (including ourselves) are appearing to be exceeding the max vehicle weights (GVWR) of 9,200 lbs. Admittedly we were over by only 400 lbs (when loaded) but this seems to be the case with most of us. (We will have to shift loads to the rear of the 5'ver and dump the firewood) We had safely, with no control issues either in normal or emergency situations, towed this way for over 10,000 miles. Some who have posted, have weights of over 1000 lbs or more over this. Some recognize the issue, some don't. While it is normally the custom to have a considerable amount of "cushion" in the "safe" or "maximum" gross weights, it is disconcerting to know that we were doing this, and it could have legal implications, not to mention insurance issues. I wonder if this is also the case with the other makes and models? It was also interesting that many focus on the max cargo or pin weights and ignore the gross vehicle weight rating (GVWR) which is the most limiting. We were within all of the axle ratings, and cargo weight limits and still exceed the Gross vehicle Weight limit. We focused on the wrong things.
Bill
edited 08/04/08 09:27am by BillandCarole *
[b][i][blue]Bill[/blue][/i] and [purple]Carole[/purple][/i][/b]
Toyota 4x4 Access Cab w/towing package
22 Ft Alpine lite
Honda EU2000 to power the toys
Garmin GPS's
"And were still wandering..."
Note: Due to invalid formatting, all formatting has been ignored.
1997 Dodge 2500 HD with Cummins Diesel (automatic):
Loaded to go camping with myself, wife, hitch,gear and full fuel:
Steer Axle 3780
Drive Axle 2620
Gross Weight 6400
GVWR* 8800
TV and Cougar 293 SAB Loaded: (No water in tanks)
Steer Axle 4080 (GAWR 4500)
Drive Axle 4440 (GAWR 6000)
Trailer Axle 7920
Gross Weight 16440
Gives Loaded 5er weight of 10040.
True Hitch Weight Loaded: 1820 (within limits)
Axle weights within limits
TV and 5er GCWR 440 over--gonna have to lose some gear and maybe make
wife walk (just kidding).
Interesting 5er weight because empty weight is listed just shy of 9000# by manufacturer and I can almost guarantee I haven't added 1040 lbs. of gear.
2008 Ford F450 Superduty Diesel dually
2008 Keystone Cougar 293SAB
