RV.Net Open Roads Forum: Whats Your Real Weights? Truck and Trailer. The Real Deal
 > Whats Your Real Weights? Truck and Trailer. The Real Deal
Page of 27
Fifth-Wheels Related Tips
B W M
Princeton IN.
Posted: 10/04/09 08:35am Link  |  Quote  |  Print  |  Notify Moderator
Ready to row 22.900+
BarbChapman1950
Wentzville, MO
Good Sam RV Club
Posted: 10/14/09 05:20pm Link  |  Quote  |  Print  |  Notify Moderator
New to the forum - Reentering camping with an 02 Jayco Quest 5th wheel, 26 feet. Need a truck. I thought the trucks GVWR had to be over the weight of the trailer (with cargo, people, etc). Is that correct? Think the trailer is 8600 lbs,but am going to check with Jayco. Looks to us that no 1/2 ton would do it, so thinking 3/4 ton. Looking at this real weights post however, I am thinking I may have it wrong as it appears quite a few of the trailers exceed the tow vehicles rating? Can someone help?? Thanks!! Barb
sirdrakejr
Las Vegas, Nevada
Good Sam RV Club
Posted: 10/14/09 10:50pm Link  |  Quote  |  Print  |  Notify Moderator
Do a search in this forum for GVWR and stand back. You will find all the answers you need with some you don't!
Good luck and welcome back.
Frank
RV.net blog
For those of you looking for expert advice, here ya go!
Frank
B W M
Princeton IN.
Posted: 10/16/09 11:42am Link  |  Quote  |  Print  |  Notify Moderator
ramcneal wrote:
siberian wrote:
OK, I just got off the Cat Scales in Battle Creek Mi. 02 F-350, SRW, CC,4X4, 7.3PSD, auto. 5er is a 1997 30ft Wildwood. Steering axle 4980, drive 4580, trailer axle 6740. Why is my steering weighing more than my drive axle? DW and myself, and 1/2 tank of fuel. Can somebody explain this to me.
That's easy. Diesel engines are heavy. There's an article on esacpes.com (I think that's the right forum) talking about using Class 8 trucks for towing 5th wheels. In the article the author talks about avoiding a certain model of Cummins engine because without the weight of a real trailer you run the risk of being over weight on the front axle.
YES your fifth wheel is mounted to close to the cab. See if your fifth wheel is a adjestable.If so you need to move it back from 1 to 2 inches. 1 might do it for you.== GOOD LUCK Here is my truck frunt 5.160 Both 12.160 truck trailer 28.200+ both trailer axles 10.880
* This post was edited 10/16/09 11:49am by B W M *
ramcneal
Colorado
Posted: 10/16/09 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
His 5th wheel might not be located to close to the cab. He should weigh his truck when empty to determine if the 5th wheel is adding any weight to the front axle. My truck (Dodge 2500 Cummins quad cab 4x4) weighs in around 4500lbs on the front axle without the trailer which is not much lighter than his truck.
2008 Keystone Challenger 32RKS
2006 Dodge 2500 Cummins, 6-speed manual, exhaust brake, air bags, Rancho 9000 shocks
Tireman9
Akron, OH
Good Sam RV Club
Posted: 10/16/09 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
BMW
Isn't the GCWR 23,000#?
I am having trouble understanding your weights.
BigCL
usa
Good Sam RV Club
Posted: 10/16/09 11:25pm Link  |  Quote  |  Print  |  Notify Moderator
TV: 2009 2500HD
Steer Axle 3800
Drive Axle 4480
Trailer Axle 7120
Total Axle 15400 (per CAT scale)
Weight of TV w/o Trailer with a full tank of fuel 6740lb
Trailer WT Loaded 8660
Pin WT 1540
GCWR 16000
* This post was last edited 10/21/09 07:54pm by BigCL *   View edit history
2009 Chevy Silverado 2500HD
2007 Laredo 29RK
Prodigy P3
16k Husky EZ roller Hitch
John Holveck
Midlothian, TX
Good Sam RV Club
Posted: 10/20/09 11:34am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2008 Ford F350 DRW King ranch. I weighed it soon after I bought it in 2008 and the weights empty were steer axle 4780lb Drive axle 3680lb gross weight 8460lb. I weighed it with my Newmar Cypress trailer yesterday (10-19-2009) and the weights were steer axle-4720lb Drive axle-6840lb Trailer axle-11700lb Gross weight-23260lb. According to my owners manual this truck is rated for a combined gross weight of 23500lb. My wife wasnt in the truck and ther were no groceries or clothes in the trailer but other that that it was pretty much ready for a trip. 1/4 tank water and full propane.
marspec
West Virginia
Posted: 10/20/09 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
2008 F450 Pick Up
Ready to tow w/hitch, full fuel:
Right Front - 2450 Left Front - 2475
Right Rear - 2000 Left Rear - 2152
With Fiver:
Right Front - 2500 Left Front - 2500
Right Rear - 3350 Left Rear - 3650
Fiver:
Right Front - 3150 Left Front - 3175
Right Rear - 2700 Left Rear - 2925
Trailer Weight Total 14950 with pin weight of 2950
Combined Weight Truck/Trailer 23950
sloman2001
Bristol, IL
Good Sam RV Club
Posted: 10/21/09 09:07am Link  |  Quote  |  Print  |  Notify Moderator
2009 Ford F-350 6.4PSD 4x4 SB SRW, 18K Superglide Hitch
2010 Keystone Cougar, Mountain Package, Polar Package Plus, Dinette Table & Chairs
When Weighed there were 330 lbs of occupants (me and the DW), the Superglide hitch, full 30 gals deisel, empty trailer but 60 lbs propane.
Truck Only (full deisel, 330 lbs of occupants, and 18K hitch)
Steer Axle Drive Axle GVWR
Rating 6,000 7,000 11,400
Actual 5,080 3,620 8,700
Buffer 920 3,380 2,700
Truck & Trailer as described above
Steer Axle Drive Axle Pin Wght Trlr Axle GCWR
Actual 5,160 5,180 1,560 7,680 18,020
Buffer 840 1,820 4,980
Page of 27
