RV.Net Open Roads Forum: Whats Your Real Weights? Truck and Trailer. The Real Deal
 > Whats Your Real Weights? Truck and Trailer. The Real Deal
Page of 15
sirdrakejr
Las Vegas, Nevada
Posted: 09/13/07 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
I think it would be interesting also to see the actual GVWR of the truck and 5th wheel and the GCWR when towing. It would tell us about how many stay within the ratings per the manufacturer. NO flames or recriminations needed. If I see them, I delete them. Just give us the true numbers.
Frank
RV.net blog
For those of you looking for expert advice, here ya go!
Frank
lincster
Mesa Az
Posted: 09/13/07 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
Frank
I gave that info in my post, I am within my manufactures ratings.
2006 F350 PSD CC 4X4 Dually w/Tow Boss package to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
Kennedycamper
Algoa, Texas
Posted: 09/13/07 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
01' Dodge 2500 CTD/6speed, 03 HitchHiker LS 30.5 RLBG GCVW 18.4Klbs 4200lbs on front tires , on 5600lbs rear tires, 8600lbs on trailer tires.
PA12DRVR
Katy, Texas
Posted: 09/13/07 03:19pm Link  |  Quote  |  Print  |  Notify Moderator
Can't give complete information...but what I have from the last CATS weighing:
With 5th wheel attached
Truck GVW from adding front & rear weights: 12,425#'s vs. F350 GVWR of 13,000#
GCVW of 24,450 vs. GCVWR of 26,000 for F350 (w/Tow Boss)...within limits.
Don't recall exactly, but am about 700#'s under FAWR and about 1500#'s under RAWR
CRL
Temporarily (5 years & counting)displaced Alaskan
My Other RV is a 1946 PA-12
RedRam
Moved from the smallest county in Texas
Posted: 09/13/07 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
18,300 lbs loaded and on the road for camping.
* This post was edited 09/13/07 05:25pm by RedRam *
04 Dodge CTD
08 Bighorn 3370
Bull Rider
Washington, The State
Posted: 09/13/07 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
2006 Chebby, Dmax, Crew Cab, 4x4, with cab high Raider Canopy, full fuel, big dog, and pretty girl = 7500. 4300 front, 3200 back.
2006 294rls 30' Cougar TT, loaded, holding tanks and water tank empty, full propane, ready to go camping = 7260. (Dry weight advertised as 6500)
Well within limits of TT and TV.
FalconLover
Southern California (Whittier)
Posted: 09/13/07 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
2004 Ford F350 Crew cab Lariat, dually with PSD & auto trans - 8,800 lbs
2004 Montana Mountaineer 297 RKS (33') - 11,400 lbs gross fully loaded
John
The Rutters
2004 Ford F350 Crewcab Lariat FX4 (4x4) DRW
6.0 PSD, Torque Shift, Jack Rabbit roll top cover, Rosen widescreen DVD system
2004 Montana Mountaineer 33' fifth wheel (297RKS) w/double sofa option
1965 Ford Falcon Futura (Pro Street/Driver)
RussC
South Louisiana
Posted: 09/13/07 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
TV--2006 Ford F350 Lariat--6.0
DRW--Crewcab--FX4--Tow Boss pkg.
GVWR 13,000--GCWR 26,000
CAT scales HWY 90 Truck Stop--8780 lbs.
Full fuel--hitch--Tool box--2 passengers (ready to hook up)
Trailer--2004 Wilderness Advantage A X 6 34.5 RLTS
GVWR 14,400 lbs.
Old Ticket Dry weighed from dealership--10950 lbs. (paperwork says dry weight 10,300)
Latest ticket weighed loaded for trip--13108 lbs.
Small amounts(not known) in fresh water and black water tanks
CAT weight hooked up 22,185 lbs.--that's 297 lbs difference from seperate weights. Not bad though.
Russ & Sharon
2006 Ford F350 DRW Lariat 6.0 PSD TrqSfht 4WD CC LB "TB"4.30
2004 Wilderness AdvantageX6 345RLTS (Triple Slide)
Happy Rving!!
fj12ryder
Platte City, MO
Posted: 09/13/07 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
TV- 2001 Dodge diesel dually quad cab 3500 with full tank of fuel, hitch, and us: 7775lbs. GVWR is 10,300 I believe. GCWR: 20,000lbs I think for the 3.55 rear end.
TV with 5er: 10,250lbs equals a pin weight of 2475lbs.
5er is 2003 Montana Big Sky 3280RL: Loaded weight with all empty tanks: 9920lbs.
GCVW: 20,170lbs.
The motorcycle trailer adds about 1500lbs total, and takes 230lbs from the pin weight. GCVW: 21,700lbs.
These weights are all from the CAT scale here in Platte City.
Howard and Peggy
"Don't Panic"
me1magoo
Posted: 09/13/07 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
TV= 2005 Dodge 3500 Single Rear Wheel Quad Cab Cummins/ Manual 6 speed 4WD
Empty truck, only full of fuel, hitch in bed and driver (me)= 7600 lbs
GVWR 9900 lbs Front GAWR 5200 lbs, empty 4560/ Rear GAWR 5200 lbs, empty 3040
Trailer= 2006 Coachmen 28' Spirit of America 526RLS with second A/C in BR and no extra goodies in the trailer (picked it up after service w/ empty tanks and of course minimum "stuff")
Pin weight 1620 lbs, Axle weights combined 6320 lbs GVWR 8600 lbs/ Total trailer weight fairly empty is 7940 lbs.
TV weights with trailer hooked up are: Front 4560, Rear 4660 for Gross Vehicle Weight of 9220 lbs. That leaves 680 lbs for wife, dogs, firewood, jacks and extra hitch pin weight- not a LOT. Trailer has 660 lbs of capacity left, again- not a LOT. I feel that the trailer is way too close to max GVWR with very little in it, the 2nd A/C didn't add but about 150 lbs total, the design is just too close to the max weight. I am comfortable with the truck weight even if I go over 10,000 lbs, I just wouldn't want to get too close to the combined Axle Weight Ratings of 11,400 lbs. Hope that meets the requirements.
Mat
'05 Dodge 3500 SRW 4x4 QC LB SLT- CTD 325HP/610TQ w/ 6 speed manual
'06 Coachmen SOA526RLS 28' 5th wheel Loaded PLUS
Bearing Buddies, Kingpin Stab., Slide Out Stab., Roof Vent & Tire Covers, 15K BTU ducted A/C+ 13.5K in BR, 100W Halogen back up lights
Page of 15
