RV.Net Open Roads Forum: Hybrid Travel Trailers: Winterizing with air pressure
Open Roads Forum  >  Hybrid Travel Trailers
 > Winterizing with air pressure
Hybrid Travel Trailers Related Tips
sknight603
New England
Posted: 09/16/07 06:37pm Link  |  Print  |  Notify Moderator
For those who winterize by blowing the lines clear of water, what kind of adapter do you use on the city water inlet and how much PSI do you use?
________________________________
2005 F-150 King Ranch SuperCrew
2007 Jayco 26L
Equal-i-zer WDH / sway control hitch
Tekonsha P3 Brake Controller
Webshots Pictures
tom_kat
way upstate new york/lake george area
Posted: 09/16/07 06:52pm Link  |  Print  |  Notify Moderator
made my own from a iron pipe reducer and a valve stem , i set the compresser at 40 lbs, i have a connector that i can put on the air hose it hooks to the stem and clips on and air will run threw all the time its clipped on the stem,first i drain everything then close the drains , open a faucet befor putting it on,i do each faucet till the waters gone when im done i let it blow air threw all the lines with all the faucets open for awhile to dry them out more then reopen the drains and its done add antifreeze to drain traps.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
USAFBILL
Alabama
Posted: 09/16/07 07:12pm Link  |  Print  |  Notify Moderator
I bought my adapter from CW, but think that I have seen them at Walmart also. It is a plastic thing that screws into the inlet with a valve stem on the other end. You can even use a regular tire pump. I usually run the pressure at 20 pounds to keep the "splash" to a minimum out of the faucets. Never run more than 40 pounds or you might blow a connection.
Good Luck
Maverick1023
The Great Lakes state
Posted: 09/16/07 08:52pm Link  |  Print  |  Notify Moderator
Don't forget to work the hot water heater bypass valve a couple of times, too. ( voice of experience )
Brad & Margi - TC & Princess
'06 Fleetwood Expedition 38N-Freightliner XC-Cat C7 300HP-Allison 3000 MH 6 Speed
7x10 trailer containing '96 Golfcart or towing '04 Dodge Ram 3500 Quad cab 4x4
Good Sam Life Members, FMCA, Harley Owners Group Life Members
NRA
Chuck_S
Broadview Hts, OH, USA
Posted: 09/16/07 09:18pm Link  |  Print  |  Notify Moderator
'06 Roo 23SS behind '07 Expedition out of Cleveland
Our Photo pages
Hoppers4
Port Orchard, WA
Posted: 09/16/07 09:40pm Link  |  Print  |  Notify Moderator
Made an adapter that goes from the city water hose connection to the air compressor quick disconnect using parts bought at Home Depot. I keep the pressure under 40 lbs and cycle through all the faucets being sure to include the john. Also also have a couple of low point drain that I include in the valves that I open. Good idea on the water heater bypass Maverick1023!
08 Winnebago Sightseer 29R
risingsun
Prescott, AZ
Posted: 09/16/07 09:49pm Link  |  Print  |  Notify Moderator
Yep - bought mine at Walmart for a couple bucks. I think mine was a CAMCO product. Cheap but effective.
2006 Rockwood Roo 23SS
2004 GMC Yukon SLT
aftermath
Washington State
Posted: 09/16/07 10:02pm Link  |  Print  |  Notify Moderator
I went to the hardware store and purchased a brass hose coupling and a quick connect compressor fitting. I power up my compressor and connect the hose. I don't have to sit there and hold the air to the plastic connector. I use the same fitting to blow out my sprinklers each fall.
I run the whole system at 45 pounds and run it through the pressure reducer just like I do when hooked up to water.
It works for me. Thanks for the tip about the heater bypass valves. I haven't done this but I will now.
2008 Toyota Tundra, Double Cab, 5.7L V8
2006 Airstream 25 FB SE
Equalizer Hitch
Prodigy Controler
sknight603
New England
Posted: 09/16/07 11:01pm Link  |  Print  |  Notify Moderator
By "working the hot water bypass valve", do you mean I should allow some air to flow through the water heater, while the system is under pressure?
SJones37
Upstate NY
Posted: 09/17/07 04:33am Link  |  Print  |  Notify Moderator
I open my bypass so no air is going threw the hot water heater.After im done i pull the plug on the hot water heater to make sure all water is out from the tank.Im not sure if blowing air threw the tank will get rid of all the water so i take the few minutes to drain it properly.
06 Dodge 1500 Ram Sport,5.7 Hemi
2005 Antiqua 215SSO
Reese trunion round bar
Scott,Lisa,Dan,Megan(also 2 jack russels that dont camp)
Our Photos
