RV.Net Open Roads Forum: Toy Haulers: My Lights Keep Surging
Search only in Toy Haulers
 > My Lights Keep Surging
bugman696
Yuma, AZ
Posted: 09/23/07 08:06pm Link  |  Print  |  Notify Moderator
I changed my battery out and it shows 12.2 volts on my battery charger and my indicator panel show that it is taking a charge (sometimes) other times it shows not charging. My lights surge up and down. Is this my inverter going bad, or is it bad. I checked the 50 amp breaker by the battery and it shows 14 something on it. My fuses on the inverter are both good and the fan comes on quite often. any help with this would be appreciated
mikew9
Posted: 09/24/07 01:59pm Link  |  Print  |  Notify Moderator
It may only be a loose connection. I'd first track down every connection and look for looseness and/or corrosion.
If you are having problems in particular with the batteries be sure to check that the connections there are not corroded and the batteries have fluid. If you can get them to an auto parts shop they can/will typically test them for free. Hope this helps.
Mike in Texas
fly-boy
Los Angeles, CA
Posted: 09/24/07 02:57pm Link  |  Print  |  Notify Moderator
If the lights are surging only when running the generator it is the charger/inverter.
My orginal unit did this and when I contacted WW regarding the problem the tech told me the units they use are absolute junk. I switched mine out for a unit I purchase at Camping World and no more problems.
2008 GMC 3500 SLT Duramax
2009 WW HKD plus 4 feet
2008 Custom Rhino
2005 CRF 450
2008 KTM 50
2006 KFX 50...
RACES5W
Redlands, CA
Posted: 09/24/07 03:09pm Link  |  Print  |  Notify Moderator
I agree... If the lights are 12V any surge or drop will be via the battery as the primary source in the power chain. If the battery(s) are properly filled and charged, there should be no or little noticeable lighting surge.
BTW... what kind of battery set up do you have? If you are running your inverter on 12Vs, you may want to think about going to 2- 6V deep cycle golf cart batteries.
Most charger/converters will put out 12 to 14+ volts, the average being 13.8V. So both readings depending on the meter are correct. The cheaper led meters will only show 12V right up to 13.99999999999999999999999999 volts.
If the 12V lights are surging when the inverter is on, the inverter's draw is simply pulling juice away from the coach when it cycles into and through higher draws. One way to stop this is to split the batteries. One (set) to run the coach and one to run the inverter.
Jeff
RACES: Radio Amateur Civil Emergency Service
bugman696
Yuma, AZ
Posted: 09/24/07 06:00pm Link  |  Print  |  Notify Moderator
Thanks for all the input...The battery I have is a deep cycle marine battery (1) and it is brand new I got it on friday...i will back up a bit...I went into the trailer on Friday to get ready to go and tried to put my bunks up and the lights completely went out and the beds stopped raising, then in 20 seconds the lights would come back on and the beds could be raised another couple of inches...this went on until I could get the beds all the way up...(I was hooked to shore power at the time)...I checked the battery and it showed bad, so I replaced it and here I am back at the beginning...It seems that my lights are very dull and just get bright when it surges...I did have my generator running all weekend and my panel would show that the battery was getting low so I hooked my manual charger up to keep running but it still does it even with the external charger hooked up...BTW it is a Raptor 05 3018TT...
ranger951
92879
Posted: 09/24/07 11:25pm Link  |  Print  |  Notify Moderator
Check your breakers also, I had the same problem and tracked it down to the breaker. It was making a loose connection to the bar. The guy at home depot said the one I brought in was a piece of crap, FWIW. I bought an extra for a spare in case another one goes bad.
Mike
2007 WW FS3000
2000 Ford Excursion 7.3TD
Hensley Hitch
2006 Polaris Ranger XP
2005 Polaris Predator 50 x 2
2006 Honda 50
2006 Polaris 200
RACES5W
Redlands, CA
Posted: 09/25/07 01:57am Link  |  Print  |  Notify Moderator
[b]This is starting to sound like something you need to get with your dealer on. The thing that scares me is the slow rebound. I fear somewhere the draw may very well be exceeding the wires limit and could result in a fire. There are just too many things that need to be checked that are (respectfully) beyond your electrical skills and knowledge. Hopefully it's something simple. But if it's not, your trying to fix it on your own might violate the warranty. Or worst, you might miss a collateral problem that might also result in a fire. I strongly suggest you immediately disconnect the shore power and battery leads and get it to the dealer ASAP! Jeff
Note: Due to invalid formatting, all formatting has been ignored.
dalton4
Anchorage, AK
Posted: 09/25/07 02:17am Link  |  Print  |  Notify Moderator
Jeff, is your battery compartment vented?
RACES5W
Redlands, CA
Posted: 09/26/07 01:35am Link  |  Print  |  Notify Moderator
Very much so... The bottom corner is open to the air.
FYI... I live in a rural canyon so I closed it off with some .25 inch mesh to keep the critters out.
Jeff
bugman696
Yuma, AZ
Posted: 09/26/07 11:03pm Link  |  Print  |  Notify Moderator
Thanks for your guys help...I do have an appointment at the dealer in 9 days...I will have them take a look at it and hopefully get me back to the dunes with full power....thanks again for your input
