RV.Net Open Roads Forum: Tow Vehicles: Silverado rear axle lube
Search only in Tow Vehicles
 > Silverado rear axle lube
clspds
SW Pennsylvania
Posted: 09/28/07 07:50am Link  |  Print  |  Notify Moderator
I have a 04 3500 dually with 26000 miles. 19000 miles are heavy towing. I have searched and can't find recommended mileage to change rear axle oil. Does anybody know the recommended mileage for a change. Thanks
2004 Chevy Silverado 3500 DRW D/A
2004 Excel Limited 33RSE
10.5 Dave
Central Ohio
Posted: 09/28/07 07:52am Link  |  Print  |  Notify Moderator
100,000 miles IIRC for a chevy.The have long life synthetic from the factory.
2007 Revolution LE 40E 2007 Pontiac G6 3100 lb toad
2000 Camaro SS 10.5 Outlaw 2250hp 3000lbs
2008 Cummins 3500 DRW SLT Quadcab 4x4 RDS 60 gallon tank
BarneyS
S.E. Lower Michigan
Posted: 09/28/07 08:44am Link  |  Print  |  Notify Moderator
Moved to Tow Vehicle forum from Towing.
Capt Skup
Southern Maryland/Nantucket
Posted: 09/28/07 08:52am Link  |  Print  |  Notify Moderator
I have changed out the lubricant on every truck/jeep that I have owned early in it's life, usually before 10,000 miles. Every one of the differential covers I have removed, no matter the brand I have found metal powder, slivers, and sometimes small chips. Just part of the break-in process. I let the differential drain for couple of hours, wipe down what I can with a clean cotton rag(t-shirts great for it. Reseal and reinstall the cover and fill with the appropriate grade fully synthetic lubricant with friction additive if needed. Sometimes the owners manual will list an optional weight of lubricant for heavy,frequent towing and that is the weight I use. After that initial drain and refill, I will then go to a 5 year/60k mile schedule. If at any time the differential are submerged in water, I will replace the lube. BTW, always check your vents for proper routing. I have found some not hooked up or kinked.
Capt Skup
AD-1(AW)USN Ret.
Wonderful Wife, 3 beautiful Daughters
"Never get in a battle of wits with an unarmed man"
2008 F-450 Lariat 4x4
2008 Honda Odyssey EX-L
SunlineF281SR
SeaRay215EC
http://community.webshots.com/user/CaptSkup?vhost=community
kampinguru
Ontario
Posted: 09/28/07 09:13am Link  |  Print  |  Notify Moderator
If you take the pumpkin cover off, you might as well put on an after market one that has a magnet on the drain plug and a fill port that is easy to get at with a dipstick to check the level. Ford is 100K recommendation.
2000 F-250 S/B 4X4
2005 Cedar Creek 30RLBS
Pullrite Superglide 16K
chadsalt
sc
Posted: 09/28/07 09:15am Link  |  Print  |  Notify Moderator
he already has a drain plug with a magnet.
gillguy
Valdosta, GA
Posted: 09/28/07 09:25am Link  |  Print  |  Notify Moderator
35,000 I think.
I'll go get my book and look.
Bobby (USAF Retired)
2007 Chevy 2500 LBZ Duramax C/C, S/B 4X4
2006 Rockwood 8317SS
1973 Airstream Ambassador
Old Town Penobscot 16
Dogarms
California
Posted: 09/28/07 11:15am Link  |  Print  |  Notify Moderator
I believe it is considered a life-lube and never needs changing, just periodic checks. Nevertheless, I changed mine at about 10,000 miles, though I didn’t remove the diff. cover, and found the same crud Capt Skup was talking about. I changed it again about a year later; no crud this time. GM’s approved lube is very expensive. I’m sure it’s very good, but I don’t know anyone who uses it. Most seem to favor Mobil 1 synthetic. I now run Redline 75W-140 syn gear lube. 86k trouble free miles.
TC
'03 GMC ExCab, SB, Duramax, Allison, 4x4, Husky mudflaps, Procaps, Bilsteins, Leer shell, BedRug, Oilguard Bypass,
Caterpillar fuel filter, ISSPRO EV Pyro and Boost guages, Titan V, Equal-i-zer EQ1400, Arctic Fox 30U
dadwolf2
Henderson,NV,USA
Posted: 09/28/07 12:13pm Link  |  Print  |  Notify Moderator
IMO, the first rear oil change is the most important. Wait for 5-10k, change the oil and then you're good to go for a long time. That first change gets rid of a lot of junk.
2005 Dodge Ram 2500 CTD,4X4,NV5600,Pullrite superglide
2005 Skyline Rampage 289
Suzuki z400 & z250
Honda XR250
racechaser1
Westchester County, NY
Posted: 09/28/07 01:07pm Link  |  Print  |  Notify Moderator
Diesel Place Maintenance Schedule
Go here for all the info you could possibly need about maintenance to a Chevy.
John and Lucy
07.5 Silverado LTZ CC SB D/A
07 Cedar Creek 34 SATS 5th wheel
Pullrite Super Glide 16k
(2) Honda EU 2000i Generators
Xantrex Inverter
Timbrens
Pictures of 2500 HD and Cedar Creek here
