RV.Net Open Roads Forum: Travel Trailers: Trouble with slide out
 > Trouble with slide out
scottmeu
san antonio
Posted: 09/30/07 03:44pm Link  |  Print  |  Notify Moderator
I have a question to ask ya'll about a problem I had this weekend. I could not get the slide to extend. After about 4 hours and countless numbers of tries it finally did go out. Then when we were closing shop it wouldn't close up. What 's the problem? The TT is only 1 year old. Thanks in advance.
4x4Bob
California.
Posted: 09/30/07 04:08pm Link  |  Print  |  Notify Moderator
A little more information may help you get a better response. For example, where you hooked up to shore power or trying to operate just off the battery? A low battery will impact the performance of a slide. Also, if you provide the make and model of your TT, other owners may have a solution for you.
Bob
2001 2500 Silverado LS 4x4 6.0, 4.10
2007 Jayco Eagle 288RLS
Cocktails for 6, Dinner for 4, Sleeps 2
End of dirt road, no signs in sight, sun going down: I am not lost, just getting ready to go camping.
closurdo
Michigan
Posted: 09/30/07 04:10pm Link  |  Print  |  Notify Moderator
Welcome to the forum.
You are going to have to provide a lot more information before anyone will be able to help.
What brand of trailer? hydraulic or electric slide unit? Were you plugged into the electric when this happened or just using battery power?
Give us a little more to work with and I'm sure someone will be able to help you.
Larry
1999 Dodge Ram 2500 QC
1998 Sunnybrook 26cks
Equal-i-zer Hitch
Visit my website
kraushad
Eastern Panhandle, WV
Posted: 09/30/07 04:29pm Link  |  Print  |  Notify Moderator
Also, what happened when you pushed the button? Nothing? Noise of any type?
Dirk
Myself (34), my Wife(32), and "The Boy"(3)
06 GMC Sierra 1500 Crew Cab, 5.3L V8, 3.42rear
05 30QBSS Trail-Cruiser, Prodigy BC, Reese Dual Cam W/D
scottmeu
san antonio
Posted: 09/30/07 06:34pm Link  |  Print  |  Notify Moderator
I have an Explorer by Frontier. I was plugged into an outlet at the time. And the button made no noise at all. Usually when I push it you instantly hear the slide out moving. I'm pretty sure the slide out is electric. Sorry for my ignorance.
chevyman2
missouri
Posted: 10/01/07 12:48am Link  |  Print  |  Notify Moderator
Well this still may not be a terrific help but here goes. Your slide could well be electric, and the armature might have a bad spot in it. You know how a car starter doesnt work and you can whack it good, VIOLA it works. Your persistence on pushing that button might have moved the armature just a fuzz at a time until it finaly moved off the dead spot, then it worked.
Also you might just have a loose connection somewhere.
I may be way off on both accounts also.
Tim-DW(Kathy)-DS(KEN)
04 AVEO-DD, 03 JEEP GRAND CHEROKEE, 94 Firebird(da toy)
07 COACHMEN SOA 32FKS(stress relief center)
If Im not at the CG---I'll be somewhere else!
Total nights camped in 07 = 62
jmbstudios
Sunny Southwest
Posted: 10/01/07 05:40am Link  |  Print  |  Notify Moderator
I had the same problem with mine.
Eventhough I was hooked up to power, the slide did not move.. Well low and behold, the slide is connected directly to the battery, and the cables were loose.
I wiggled them, and VIOLA! Slide works. Tightened up the battery terminals, and its all good.
Try that. It might be the same as mine.........
Good Luck!!
Me, DW, The Girls 7yrs, and 2yrs.
1999 F350 7.3L Power Stroke Diesel!
2006 Trail Lite 27QBSS
Dont forget the music---
Guild 6 string in my Hand!
wildbyon
Tulsa, OK
Posted: 10/01/07 01:22pm Link  |  Print  |  Notify Moderator
I'll second checking the battery connections. My big slide wouldn't come in at random times even though the smaller slide would and then eventually after fooling with the switch in/out it would work. This would happen even when hooked to land power. My dealer said that the slide also required a fully charged battery. I checked the battery and found the negative cable loose. After tightening and charging the battery good, I've not had any more problems.
'01 Ford F350-7.3l PS Diesel, Lariet, Crew Cab, 4x4, Dully,
Air bag suspension, performance chip, 4" exhaust
Bulldog ATV Rack
2-'04 Honda 450S Foremen ATV's
'06 Travel Trailer-31'Forest River Cardinal
scottmeu
san antonio
Posted: 10/02/07 08:41pm Link  |  Print  |  Notify Moderator
thanks. . I looked to see if the cables were loose and the weren't, Hopefully it's just that the battery is low. Anyone else have other ideas?
rvddc
Canada
Posted: 10/03/07 04:45pm Link  |  Print  |  Notify Moderator
On the weekend I could not get one of my slides to go all the way in. The rv tech said it is off centre. The bolts ont he one side have loosened. This can happen from factory to dealership. It's an easy fix but it takes two guys. Keep us posted.
