RV.Net Open Roads Forum: What did you do to your Class C MH today???
 > What did you do to your Class C MH today???
Page of 103
Class C Motorhomes Related Tips
tenbear
Northern Vermont, USA
Good Sam RV Club
Posted: 10/15/09 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
I replaced the 40 amp circuit breaker in the line from the battery to the converter. For some reason, the breaker was opening at about 15 amps, usually in the middle of a shower at night. After a few seconds it would reset and be good for a few more seconds, just enough time to turn off some lights.
2004/5 Four Winds Dutchman Express 28A, Chevy chassis
Subaru Impreza Outback
SKIRMISH
NORCAL
Posted: 10/15/09 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
Finished installing my Hellwig rear sway bar, took a test drive, drives so much better now!
jrdr653
Home
Posted: 10/18/09 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
Cleaned inside, replace kitchen faucet, washed and treated roof, wahsed exterior, waxed cab and then drank a cold beer!
98 Tioga Ford V-10 18,000 Miles, Wife, myself and the dog.
Sometime but rarely the teenage kids. We are enjoying and experiencing our new life together.....Without the kids.
bobojay5
Eastern Kansas
Good Sam RV Club
Posted: 10/18/09 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
Cleaned and flushed the holding tanks, then added a bit of pink stuff. Also got it ready for a visit to the local Itasca dealer for some warranty work.....
Bob & Sharon
Eastern Kansas
2009 Itasca Navion IQ DL
danewguy
LI, New York
Good Sam RV Club
Posted: 10/18/09 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
Finally got most of my list done, replaced the shower valves, replaced the skylight over the shower, new vent cover for stove exhaust fan, fix my roof access ladder, and now I am looking at different options for replacing my old sewer hose set up....
1999 31ft Gulfstream Conquest Class C
Foggy
Kalamazoo Mi. U.S.A.
Posted: 10/19/09 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
Started construction of a drawer to fit below the fridge. A while back I cut out the panel below the fridge and found enough wasted space for 5 or 6 12 packs of sodas. Now I am making a drawer for easier access.
Happy-Trails
Foggy
Desertsam
Phoenix, AZ
Posted: 10/19/09 08:46pm Link  |  Quote  |  Print  |  Notify Moderator
CloudDriver wrote:
Installed MaxxAir vent covers to replace the 2 year old AeroFlow vent covers that had failed. Also cleaned the vent screens.
Replaced the solenoid that allows the house batteries to charge from the engine alternator.
Checked battery fluid levels and cleaned batteries with dilute baking soda solution.
I replaced the solenoid also on my 2004 in 2009. Yours lasted the same amount of time.
Also just replaced the A/C blower motor Fasco 1468-3069 with a 1468-3109. Same as a 7184-0155. Making noise at end of the cycle just as it turns off. Been doing it for 2 years. Oil and grease did not help long.
2004 Winnebago 25ft E450
2006 Honda CR-V
Berticus
Boise, ID
Posted: 10/20/09 09:30am Link  |  Quote  |  Print  |  Notify Moderator
Well after I overheated the brakes and lost them till they cooled off, I am setting here and having les schwab look at them. They said that everything looks good but would recommend to bleed the brakes just in case any air got in the lines because of the overheat. After this I will get her ready for the weekend of deer hunting with my boys.
Laters, Robert.
The Setup:
96' Serro Scotty 25'Dodge,4x4,Diesel,Class-C, 86 20' Chris Craft LTD.
Rich Panganiban
Southern California, USA
Posted: 10/20/09 11:05am Link  |  Quote  |  Print  |  Notify Moderator
Parked the MH in front of the stick house so we could use the facilities. Our house blew the water main, so no water for a couple of days.
2007 Jayco Greyhawk - Kodiak 32SS
'00 Subaru Outback Wagon
ronfisherman
SE Michigan
Good Sam RV Club
Posted: 10/20/09 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
Spent 3 days washing and waxing MH. Tomorrow put cover on. So MH will be clean when we leave for the south early next year.
Page of 103
