RV.Net Open Roads Forum: What did you do to your Class C MH today???
 > What did you do to your Class C MH today???
Page of 314
Eastwacamper
Greenacres, WA, USA
Posted: 11/04/11 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
Had the transmission fixed. We are done for the season and parked in the yard. Went to move it to another place, no reverse, no gears. Called Ford, they said to get a certain oil and put some in. Did that. Called an rv place who refered us to a place who refered us to a place. Found out evidently we hit something and got a dent in the pan and it caused a leak. Could have been worse.
Now I'm reading what folks are doing to fix up their rigs.
thebeach300
delaware
Posted: 11/06/11 01:10pm Link  |  Quote  |  Print  |  Notify Moderator
just got back from a nice weekend of camping cleaned out all the stuff cleaned up inside think we have one more trip the last weekend of the month.
pianotuna
Regina, SK, Canada
Posted: 11/06/11 04:08pm Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Drove it home for a fall cleaning.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
4BeachCampers
Lakewood, CA
Posted: 11/06/11 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
Well the last 2 days we got a new Tire. Filled the Propane tank. Rebuilt the kitchen drawers, AGAIN! Installed a new digital Thermostat, much easyer to use. Installed a couple new Led lights ( definitely need more) and now getting it ready for cold weather camping, thicker blankets, flannel sheets etc...
* This post was edited 11/13/11 08:51pm by 4BeachCampers *
2005 Ford Four Winds Chateau Sport 28A
W4MBG
Williamsburg, VA
Posted: 11/06/11 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
cleaned out the rv after last week's trip to luray. and found and fixed an LP leak at the tank.
1999 Winnebago Minnie, 29', Triton V10, mostly stock. So far...
Rich Panganiban
Southern California, USA
Posted: 11/07/11 10:51am Link  |  Quote  |  Print  |  Notify Moderator
Finished polishing the remaining three wheels.
Here's the front
Also added a center cap decal
2007 Jayco Greyhawk - Kodiak 32SS
'00 Subaru Outback Wagon
NoraExplora
WA
Posted: 11/07/11 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
2004 - 23ft Gulfstream BT Cruiser. Got the fridge fixed so it will switch over to gas. Installed a trickle charger. Fixed it so running the engine charges my house battery. Replaced floor carbon monoxide detector; replaced the one on the ceiling with w co2/smoke detector combo (it actually talks as well as alarms). Having all the roof seals redone (factory missed a few spots). Cleaned out water heater and checked anode.Oiled the retractable steps. Checked all fluids in engine, batteries and generator. Winterized. Still have side seams to check.
Ok, I confess. My mobile RV repairman did the work.
* This post was edited 11/07/11 08:17pm by NoraExplora *
thebeach300
delaware
Posted: 11/08/11 11:09pm Link  |  Quote  |  Print  |  Notify Moderator
has anyone ever added the pink stuff by adding it to the fresh water tank and pumping it thru the lines first time doing this thanks.
ronfisherman
SE Michigan
Posted: 11/09/11 04:33am Link  |  Quote  |  Print  |  Notify Moderator
I have done it that way. But it takes a lot of tank flushes to get all the pink stuff out of the tank.
Kodiak Chassis Class C Forum
snowdance
Yreka, Ca
Posted: 11/09/11 05:42am Link  |  Quote  |  Print  |  Notify Moderator
Drain fresh water tank first then add pink stuff to tank. Drain and Bypass the water heater if you have a bypass. If not it takes a lot of extra pink stuff depending on size of water heater. Run water pump until you have pink stuff at each location. Most RV's have water line drains at the end of the piping so open and get it there too. Drain holding tanks. Dump pink stuff down each drain. I have never had any trouble getting it out of my tanks in 20 plus years. Just drain pink stuff and flush tank twice.
Snowdance
We spent most of our money traveling... Just wasted the rest..
Chevy 7.4 Vortex
2000 Jamboree 23b Rear Kitchen
http://www.flickr.com/photos/snowdance38
Page of 314
