TMBLSN
Washington State
In your second link, this text can be found... "Recreational vehicles are not CMVs subject to Federal size regulations (Figure 16)."
Yeah, go with that, you aren't subject to any width restrictions.
You are still subject to width regulations. I was attempting to link to national information, rather than get state-specific.
Obtrusive 'extension' (not extrusion), or not, anything beyond 102", that is not actually part of the mirror, is not legal.
My class C is 102" wall-to-wall, with the mirrors extending beyond that.
Those plugs will look real nice...
rongtamw
Johnstown
Went to DMV to get new plates.Ready to hit the road.
adamroof
Camarillo, CA
wow... send the cops and the grammar police. I'm sorry about those that hurt you in life, but "rolling eyes" is straight up rude, and those that you pass your anger on to don't deserve it.
TMBLSN
Washington State
If you find the rolling eyes rude, talk to the moderators, they provided them.
Again, it doesn't matter if it doesn't even stick out beyond your mirrors. If the antenna is beyond the 102" width of the 'vehicle', then it's illegal.
It could be attached to the 'back' of the mirror, so that it doesn't stick out at all, and it would still be illegal. Only the mirror can be beyond the 102" width of the vehicle.
It doesn't get much more straight forward then this.
2001 Bigfoot 24DB (Class C)
2006-2011: 2006 Jayco 275BHS (5th wheel)
2002-2006: 2003 Northern Lite Ten-2000CD (truck camper)
2002-2011: 1998 Chevrolet C2500HD for hauling camper and towing 5er
Lee
magik235
Central Wisconsin
I got mine out of storage today then I tightened the bolts that mount the air conditioner.
1985 Sport Coach http://www.rv.net/forum/index.cfm/fuseac........d/tid/26101292/srt/pa/pging/1/page/1.cfm
Bethany Carolina
I carried out the LAST clothes basket of "stuff" to the house. Cleaned out the frig & put a fan blowing in it..making sure it's dry! Swept the floor. Now, there is a basket on the table for "stuff" going back in. ... .... :>)
oldtrucker63
Harlan Kentucky
adamroof wrote: Added Shelving
Increased storage room!
Started the CB Antenna wiring and mounting
(still need to paint bracket and finish heat shrink and will probably return antenna for a white one) You will need to run a ground wire to that bracket or you will not ever get the standing wave out of the radio.
Without Trucks,....America Stop's
adamroof
Camarillo, CA
Thanks oldtrucker! That validates me a little! The one wire that's looped up to the bracket is a ground I ran a second wire out for, and the dangling wire still needs the pl259 connector that I'm learning how to crimp and solder. I tested the ground to the negative battery terminal for continuity?? and got 0.000 so my frame point I found under a kick panel was good. Hopefully. I haven't hooked up the radio yet, maybe this weekend I'll get it all together.
cal47
Arcadia Fl
Just added a set of Bigfoot EZE Levelers.
Cal & Donna
Starr (our Lab mix)
2000 FourWinds Chateau 31S
Rickson 17.5 Wheels and Toyo tires
Sani-Con Sewer Solution
Pressure Pro System
1996 Grand Cherokee Toad W/Ready Brake System
Rand McNally RVND 5510
Bigfoot Levelers
applegater
Oregon
Just got my Alcoa alloy wheels installed.
