pianotuna
Regina, SK, Canada
Hi,
Found out my hall effect ammeters can display a negative value! I'll probably ask about changing the path of the wire to show how it discharges the batteries too.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
Off Pavement
The Silver State - Nevada
Added a Winegard Wingman to the TV antenna... tough job! Took maybe all of 2 minutes once I got on the roof.
Please Support Multiple Use of our Public Lands!
Brian & Margie
www.rv-camping.org
'10 Sunseeker Class C - Gozer II
'13 Jeep JKU (Wrangler) - Billie
pianotuna
Regina, SK, Canada
Hi,
Rolled up the 30 amp cord at my house which I forgot to do when I disconnected to return the RV to storage. (lesson--always put the cord back in the RV!!!)
oldtrucker63
Harlan Kentucky
Changed the Oil in the big 440,.....There was only about 300 miles on the oil but the last change was last winter,..She is now good to go.
Without Trucks,....America Stop's
tenbear
Northern Vermont, USA
pianotuna wrote: Hi,
Was one end attached to the MH? OUCH!!!
Good thing you have all that solar and battery capacity.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
rehoppe
Denver & Nathrop Colo or somewhere else
Thought I was the only one in that club. Mine was hooked onto the MH. It did survive.
Hoppe
2011 Dodge 1500 C'boy Caddy
2000 Jayco C 28' Ford chassis w V-10 E450
Doghouse 36' or so Trophy Classic TT
pianotuna
Regina, SK, Canada
Hi,
Took it back to storage.
Replant
Someplace
For the rear bed I purchased a memory foam mattress made in the USA and started on the repair and refurbishing of the aluminum steps on the cab. Tomorrow I'll buy a couple rolls of Skid Guard tape also made in the good ol' USA.
Replant
Someplace
Off Pavement wrote: Added a Winegard Wingman to the TV antenna... tough job! Took maybe all of 2 minutes once I got on the roof.
You lucked out. When I did the mod and lowered the antenna the Wingman wanted to hit the A/C unit. I had to unfasten the antenna base and turn it a few degrees C/W. Unfortunately there wasn't a helper inside to guide me and the shaft is off center. It doesn't turn as easy as it should but I can live with it or cut away some more wood from the inside to make the hole larger.
tenbear
I noticed the string in one of my day-night shades was frayed on our latest trip. Today I replaced the strings in the blind. Believe me, its a lot easier to do before the string has broken. This is my third one, the other two were a couple of years ago.
