Eastwacamper
Greenacres, WA, USA
Wish I could do something about the old square tv and the wood box that holds it. A cheap tv would be nice up there, newer kind. It's like above near the exit door. Any ideas welcome.
tenbear
Northern Vermont, USA
Here is my conversion from the old TV to a new LED flat screen TV. There have been several TV conversion posts, check the Tech Issues, Technology Corner and Do It Yourself sub forums.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
Eastwacamper
Greenacres, WA, USA
What an idea. Thanks for that. What size tv?
Getting ready to clean the roof and the body of the motor home. Leaving in June.
tenbear
Eastwacamper wrote: What an idea. Thanks for that. What size tv?
Its a 22 inch LED TV.
magik235
Central Wisconsin
I check the differential oil and greased the RV then finished packing. I am leaving for Sedona, AZ tomorrow.
1985 Sport Coach http://www.rv.net/forum/index.cfm/fuseac........d/tid/26101292/srt/pa/pging/1/page/1.cfm
thebeach300
delaware
changed the air filter in the v10 big air filter,going camping in morning.
pianotuna
Regina, SK, Canada
Hi all,
I started and started and started the Boliy generator. This supposedly 3300 watt generator shaped object can't run a converter (723 watts max), a 462 watt oil filled heater, the fridge (305 watts), two laptops (200 watts?) and a router (2 watts).
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
pianotuna
Regina, SK, Canada
Hi,
Had a bacon and tomato sandwich cooked via the battery bank with 100% solar power. The only mistake I've made was not having MORE solar.
tenbear
Checked the tire pressure and the battery fluid, also checked the toad's battery fluid. Still have to de-winterize it.
dichrodave
Independence, OR
Went to Camping World of Wilsonville, OR and had the Falcon all-terrain tow bar and base plate installed on my 2008 smart car. Pulls great!
