vonzoog
Delaware
When you are setting the elevation and/or skew, remember, the nut and/or bolt head is NOT the alignment mark. You must use the leading edge of the bracket as the alignment mark.
Many times this mistake had been made.
If you have to ask why I drive a Diesel, then you will never understand.
2004 RAM 2500 SLT Quad Cab 4x4
Cummins(305/355) 48RE Auto 11.5 Rear
2004 Laredo 29GR
Wherever I happen to park
IF direc had cut off your access. You get a "You have not paid for that" message
Try two things.. One check the dish type (Oval or round) make sure it's set properly
Two, PRESS THE RED BUTTON (Reset the receiver) or do the menu settings reset - - - thing.
USAFBILL
Alabama
There is a Mexican satellite setting just a few degrees off and some lock on to it and have the same problem your having.
Good Luck
computerbug
Sarasota
Check the elevation setting on your dish. You can display the correct setting based on the zip code where you are camping. This is on the receiver's menu. I had a similar problem at a local campground, and the dish elevation had been knocked off its normal setting when I stowed it in the bay for transporting. The receiver locked on to some non-DirecTV satellite. You can also test by setting up your mobile dish at home with your home elevation setting and see if you get all the channels.
Jim & Joan
Milton, WI
If your dish is a oval triple LNB check the azimuth, elevation & tilt for the zip code area you are in
USAFBILL wrote: There is a Mexican satellite setting just a few degrees off and some lock on to it and have the same problem your having.
Good Luck
Your are thinking of Sat-Mex 5 at 99, The direc receiver won't lock on it, and it's an American bird, HUGHESnet uses it. and Hughes paid to put it up there. It is called "MEX" cause... Well, I suspect it's south of Mexico, just like 110 is south of Az and 119 is south of just west of LA
RichieO
Broward County, Florida
Thanks alot folks... I will try again and see how it works out.
2005 JayFlight 27BH
2003 Dodge Ram 1500 QC 4x2 Hemi 3.92 Super Springs
Our Photo's
flhtci-rider
Montreal, Canada
some times U need to remove and reinsert the card and let the system reboot.
2006 Scepter
2008 24' Haulmark EDGE
2003 Grand Vitara
My best friend DW
1 fur ball Max (AKA - PITA)
And enough solar power so I never have to start the Genni
snydeda
Seattle
Reading through I noted you used a meter to test strength, however I did not see where you used a compass. If you don't its very easy to get a strong signal, however it might be on the WRONG satellite. The other problem solving ideas are valid for certain problems.
Your Old Dog
Western New York
Dakota Ted wrote: I am having the sme problem but my wife came up with our solution. we unplug the tv and reciever and wait 20 seconds and plug all back in and it goes through a install proceedure and all is well again. don't no why but it works fo us
I've had the same problem and Dakota Ted's suggestion worked for me everytime. Just remember, it takes the system awhile to find all the channels, maybe 10 minutes.
