RV.Net Open Roads Forum: Dinghy Towing: Ignition Key In Lock
Search only in Dinghy Towing
 > Ignition Key In Lock
5etechsupport
South Florida
Posted: 11/06/07 09:41am Link  |  Quote  |  Print  |  Notify Moderator
I'm new to RV'ing and have stick 2007 Ford Fusion as a toad. The owners manual says to leave the ignition off and the steering wheel lock off. To me, this infers that you leave the key in the ignition. Am I correct or do you remove the key and hope the steering wheel doesn't turn far enough to engage the lock. I would appreciate any input or experience. Thanks.
Happy Harry
Redding, California
Posted: 11/06/07 09:56am Link  |  Quote  |  Print  |  Notify Moderator
You leave the key in the ignition, and the steering wheel unlocked.
You should get a couple of extra keys and keep one in the motor home, used just to unlock the towd car door.
HARRY
RetiredbutWorking
Waiting on retirement in Central Texas
Posted: 11/06/07 11:44am Link  |  Quote  |  Print  |  Notify Moderator
Yes, you leave the key in the ignition.
lampooner
South Carolina
Posted: 11/06/07 11:58am Link  |  Quote  |  Print  |  Notify Moderator
Not sure about Fords, but on GMCs, you can have a key made without the digital encoding. It will unlock the steering, but can not be used to start the engine.
Lampooner
Remember you are only young once,
but you can be immature fotrever!
5etechsupport
South Florida
Posted: 11/06/07 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks folks, I went to my Ford dealer and had a key made which opens the door as well as unlocking the steering column. It will not start the engine. I also had one made that has the chip for starting which I programmed. I'll be keeping both in the MH and will get a spare set of MH door keys to keep hidden in the toad. Thanks again for the feedback.
