digitalRV
fl
Hi
I just changed my oil to all amsoil oil and filter.
i have a new fuel filter but in the manual i see no directions on how to change it?
This is for a 1998 Dodge 3500 24 V diesel.
How do i take the filter off and change it.
Or can you point me to a web link showing this.
Thanks
Perrysburg Dodgeboy
Perrysburg, Ohio USA
You can find the info at either one of these web sites.
truck resource
TDR
Perrysburg Dodgeboy
2004 Dodge Ram 2500 Quad Cab SLT Cummins HO
2005 Keystone Cougar 304 BHS
How many remember this?
Pics of stuff
RRUGG
Newaygo, MI,USA
It's a spin-on filter like an oil filter. Unscrew it and screw on a new one. (Unless they've changed things since I changed them on my 1996 3500. On later trucks I had the dealer do it because I got lazy.)
RRUGG
2009 Chevrolet Silverado LTZ 1500 4x4 5.3L
2011 Kodiak 281RLGS travel trailer
2011 Egg Camper
2010 Chrysler Town & Country
Good Sam life members
Bob & Grace professional retirees
Camped in 49 states. Missing Hawaii.
Hannibal
Gas Station
They've changed. My '01.5 and '03 were a cartridge filter in a filter housing. I would drain a little fuel out of the filter with the yellow lever, remove the cap/filter with I think it was a 1-1/8 socket? Swap the elements and O-ring, check with a flash light for any debris in the canister, re-install the new filter and just snug the plastic cap down good. Clean fuel goes down the tiny hole in the tit sticking up the middle of the canister so be sure you don't get any foreign matter in there. Don't wipe it off either. It will be clean if you haven't contaminated it. If you buy a good Fleetguard fuel filter, it'll have a new O-ring and a little folded intruction leaflet in the wrapper. To re-prime the filter, turn the key on but don't start it a couple of times for a few seconds. You'll hear the fuel pump humm for a few seconds each time. Some folks like to drain all the fuel from the canister but I never did and don't see any reason to. The last few changes I didn't drain any fuel from the canister and it started right up after. The old filter would soak enough fuel out with it to keep the canister from over flowing when I took the old filter out. One more thought. Some of the caps had a 3/8" drive hole in the middle of the 1-1/8"? socket fitting. Don't use the 3/8" drive hole. The plastic will break before the cap comes loose and you'll use horrible language...
'10 F250 XLT CC SB 5.4L 5spdTS 3.73
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
'07 KZ Jag 28JFSS.
m16fullauto
Louisburg NC USA
On my 2004 CTD, it is a canister type filter. Drain the diesel in the canister, close the valve back up and remove the top lid of the canister. Remove the filter cartridge & rubber O ring and insert new filter plus O ring on the top lid. If you notice on the top of the lid, it will be stamped with the torgue seting. Use a torgue wrench and you'll also need a swivel socket. DO NOT overtighten or you will crack the canister / lid and allow air to enter the fuel rail / injectors which can be costly to fix plus blowing diesel all over the place. Once this is done, turn the ignition on a few times til the fuel filter / canister is full of fuel and the fuel pump no longer makes the buzzing sound which means it is full of diesel and ready to crank
2004.5 Dodge 2500 Diesel 4x4
2006 Jayco Jayflight 31BHDS
johntank
Oxford, Ms 38655 USA
Be sure to take the water sensor out of the old filter to go back in the new filter, the new filter should come with a new O-ring for the sensor.
Hannibal
Gas Station
johntank wrote: Be sure to take the water sensor out of the old filter to go back in the new filter, the new filter should come with a new O-ring for the sensor.
True for the 12v Cummins. The 24v Cummins starting in '98.5 held the water sensor in the canister. It doesn't come out with the filter...
ib516
Up here!
What Hannibal said. 1 and an 1/8" socket, he's right on the water sensor thing too.
This may help. The fuel filter is the cannister directly UNDER the #6 (not what the #6 is pointing to) and directly ABOVE the #17. The "nut" on top is the 1-1/8" molded in nut. The plastic lid that you remove is black.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY
Scangauge2 for Boost, Coolant temp, rail press & Trans Temp
PICS
Collision Reconstructionist, CDR (automotive "black box") download technician/analyst
digitalRV
fl
Ok this sounds like i must be very careful not to break it.
MMM do you think I need to change it right now..I dont want to mess it up.
We leave on Monday for a 3 month trip in our 5er..
The Mad Norsky
Yankton, South Dakota
I'm not sure this would help, but the link is to a picture play by play of how to change the fuel filter on a 3rd generation Dodge Cummins.
If anything, it might give you an example to follow with your particular style filter.
Changing fuel filter 3rd generation Dodge Cummins
The Mad Norsky, Doll, Logan, Korey & Rocky
2011 Ford F350 Power Stroke dually
RV'ing since 1991
We never know where we're going till we get there!
