BK&Family
Danielsville, GA
Anyone using one of these RV5 Extended King-Pin http://www.popuphitch.com/rv5.htm? I am looking for something to keep me from getting a slider hitch. Also, if using did it impact the warranty on the camper? TIA for the help.
'04 2500 4x4 QC auto 3:73 FASS,PSM Cold Air,Amsoil by-pass SRT Hood,BIG Mouth Grill ARE top,EMS Off Road Hub Conversion(4 MPG gain),Rancho RS9000X Shocks and more to come...I hope '05 32' Open Road TT with Hensly hitch
The smell of diesel......priceless.
joshjack
Alabama
I just put one on. Real happy, but I couldn't speak as to the camper warranty.
J
03 Ram 1500 Quad Cab with Hemi 5.7, HD tow package, K&N Cold Air, B&W Companion + Ball, Prodigy,
Macbook Pro 17" (Fastest Vista Laptop , iPhone)
Me and the DW and our
2 Dogs: Jackson (golden), Pumba (min-pin)
Vulcaneer
Northern New England
My take on extended pin boxes. They work OK...I guess. But you need to buy a new one with every 5'er you buy. Or take it off and install it on your new trailer. If it fits.
On this particular item it raises the trailer pin box about 2 inches. That would be a concern. And while it clamps to the pin. While it probable would be OK, it just does not seem to be all that "positive" to keep it in position. I just don't like that idea.
2006 F350 V10 4X4 SC SB SRW 4.30 22,500 GCWR
2011 Open Range 393RLS 14,250 GVWR
Pullrite Super Glide 18K
Super Duty, Super Cab, SuperGlide
mapguy
Puget Sound
If you install this Pin extender, then have some type of frame failure -you will have a hassle to deal with. These days manufacturers void warranties for very simple things -thus forcing you to prove in an "engineering sense" that the modifications had no bearing on the failure. Extended warranty companies will also use this ploy....Magnason Ross Act (SP) does make it illegal to sidestep warranty for manufacturers dirctly when modifications are present but they can put the "burden of proof" on your shoulders .... which can be an indirect cost of your decision.
For me personally, the difference in purchase price between a Pin Extender or an auto slide hitch or a new slider base rail set (if already own 5er hitch) is to little to take the risk.... especially if all the potential costs are factored -direct and indirect.
Map Guy
noman'sland
Boise City OK
I've used one for about two years, no problems. I changed it to use a Mor-ryde pin box, tho. When looking at all the differnt cushioned pin boxes, found a spec sheet from Trailair that states not to go beyond six inches in extension, so the added four inches should not be something that would cause a frame failure. I've always felt that the frame should be stronger, particularly it the pin box area.
Vernon & Martha
02 F250 PSD 7.3 4x4
00 Montana 3280rl
dbbls
Missouri
Seems to me like it would put more stress on the pin box. I would check with the trailer manufacture as it may void the warranty on the frame.
2011 F-350 CC Lariat 4X4 Dually Diesel
2004 Colorado 29RL 5th wheel with 3600 watt Onan
joshjack
Alabama
noman'sland wrote: I've used one for about two years, no problems. I changed it to use a Mor-ryde pin box, tho.
I think a Mor-ryde, 5th airborne, or similar is probably the best solution because you replace everything from the pin-box down. You should also check with the manufacturer of your pin box to see if they have one - check through your dealer.
In my case I got a used RV5 for a real good deal. I have an older, used fiver so I didn't want to spend $800 for a 5th airborne, etc.
You might also try a 5th sidewinder. Those things change the pivot point to right under the pin-box.
J
Quick trip
Cerritos, Ca.
My 5er came with the extended pin box.
I have 9-1/4" clearance and have never hit the truck while making a tight turn.
jaminjer
Menifee, California
I have one installed. I had it welded on then lowered my hitch a extra few notches to make it ride where it used to. It works great for me.
1990 Dolphin Class A 34 foot Ford 460
2006 Honda 400EX
2008 Kawasaki Teryx
jefff929
Pacific wonderland, wet side
Quick trip wrote: My 5er came with the extended pin box.
same here.
I got and have used the slider tho
2001 Dodge 2500 QC, Diesel, Auto, 4x4 Shortbox, Stull running boards, 26.5' Sundance 5er
My Baby
Another NWBomber
