scottfree
london ont
Last camping trip my refrigerator quit working on elect but worked fine on prop. When I went to come home the coach battery was dead,would that be the problem and if so why would it work on prop.
scottfree
Mousefart
New Jersey
Most models require 12v power to work even when plugged in to 120v "electric" (as we say in the states). The 12v from the battery powers the control board. Dead battery equals no cooling even with 120v power. However, with no 12v power, the fridge shouldn't work on propane either (again depending on the model).
Now if your battery is dead it could indicate a bad converter or a blown 12v fuse somewhere.
Need more info for an accurate answer.
edited 11/30/07 07:14pm by an administrator/moderator *
Paul (Mouse)
2007 Flagstaff Shamrock 17 Hybrid (heavily modified for boondocking and winter camping).
2007 Dodge Dakota Quad Cab, 4.7L HO engine, Factory tow package, Equil-i-zer WD Hitch, Prodigy brake controller.
Yamaha EF2400 Generator.
Chuck&Gail
In the Colorado Mountains
Here is my guess. Most fridges have a control board, powered by 12 volts. If battery died while board had fridge to propane, or that was default position, it would work on propane but not 120 VAC.
True? No idea, but sounds good anyway.
Chuck
Wonderful Wife
Lovely German Shepherd.
1999 Mercedes ML320 TV
2003 Wanderer 187TB Toybox (3620# UVW, 4800# loaded)
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories.
You can't take the Fisherman out of this Camper
Ontario, Canada
Just so you know, the original poster is from London Ontario. Our electricity supplier used to be called Ontario Hydro. So all our electric bills were called hydro bills. The name has recently been changed to "Hydro One"!
edited 11/30/07 07:15pm by an administrator/moderator *
1960's: Tents.. 1970's: Soft top & Hard top P/U.. 1980's: 17' RV.. 1990's: 24' RV.. 2000's: FINALLY... 2002 Cougar 276EFS; 2002 GMC 2500HD Ext Cab 4x4; (Nfld/Labrador-Yukon/NWT/Alaska-Gaspe', Que./Florida!!)
MrWizard
Van Nuys, Ca
make ? model ? age of fridge ?
control board controls switching modes, propane gas valve, igintion of propane flame
electric heating element might have burned out, or no voltage on the 120v plug for the fridge, if its old enough, 1982? there won't be any 12v control board, just manual switches
Connected via Verizon Via LG Dare VX9700
Maximum memory has been reached !
kaagee
Burlington Ontario
You can't take the Fisherman out of this Camper wrote: Just so you know, the original poster is from London Ontario. Our electricity supplier used to be called Ontario Hydro. So all our electric bills were called hydro bills. The name has recently been changed to "Hydro One"!
Now you've made it more confusing...EH. !!
Ken.
Ontario, Canada
kaagee wrote: You can't take the Fisherman out of this Camper wrote: Just so you know, the original poster is from London Ontario. Our electricity supplier used to be called Ontario Hydro. So all our electric bills were called hydro bills. The name has recently been changed to "Hydro One"!
Ken.
It wasn't confusing when I wrote it... but then a Moderator took over and even I am confused .. must be getting late!
ScottnSherrie
Augusta, GA
Chuck&Gail wrote: Here is my guess. Most fridges have a control board, powered by 12 volts. If battery died while board had fridge to propane, or that was default position, it would work on propane but not 120 VAC.
I don't think so. The board need the 12V to hold the gas solenoid open. The non-powered position for the gas valve solenoid is off.
88 Gulf Stream 34' Sun Vista, Ford 460, Edelbrock Perfomer carb, Thorley headers
Ford F-250 crew cab 4X4, 6.0 turbo diesel
complete roof rebuild
daughter 15, son 11
US Army Desert Storm vets (both of us)
left: The Ol' Gal right: DW with White Lightnin'
kaydeejay
SE Michigan, USA
ScottnSherrie nailed it - without 12V to the control board there is no signal to open the gas solenoid. Voila - no cooling!
(But I did understand the "Hydro" bit as I used to live in Ontario!)
Keith J, Retired from GM Engineering
2005 GMC Sierra 2500HD SLE 2WD/CC/SB/DA.
1999 Sunnybrook 27RKFS Fiver
Bilsteins, Line-X, Westin steps, Prodigy, Retrax, 16K Superglide, 5th-Airborne pin-box, Multi-vex mirrors.
Mousefart
New Jersey
You can't take the Fisherman out of this Camper wrote: kaagee wrote: You can't take the Fisherman out of this Camper wrote: Just so you know, the original poster is from London Ontario. Our electricity supplier used to be called Ontario Hydro. So all our electric bills were called hydro bills. The name has recently been changed to "Hydro One"!
Ken.
Sorry, apparently one of the mods has an issue with my twisted sense of humor.
So are almost all the power in Canada hydroelectric or is the term "hyro" used for all electric power even if coal or oil fired?
edited 12/01/07 06:55am by Mousefart *
