RV.Net Open Roads Forum: Truck Campers: cold weather camping
 > cold weather camping
GULFMAN
MOORESVILLE, NC,USA
Posted: 12/04/07 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
When camping in cold weather (below freezing)conditions do you do any thing different or special to your truck camper then you would any other time like the fresh water hose and water filter the landline opening and outside shower opening and the water hose opening seems to be a area that is subject to freezing.
Thanks
Gary
Lots of Stuff
WA. USA
Posted: 12/04/07 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
Depends on the camper some are made for cold weather use some are not, check your owners manual for specifics on your camper.
Our Lance with cold weather package has worked fine in +6 degrees. With water in tanks but we leave the furnace on even when driving at those temps. Set to at least 60.
DG
03 Chevy Silverado Regular Cab 2500HD 4X4 Duramax
04 Lance Lite 915
c.traveler2
Moreno Valley,Ca.
Posted: 12/04/07 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
Our Lance 815 doesn't have a cold weather package and been able to do zero degree cold by keeping the furance on, the cabinet door under the sink open. This allows warm air to get to the hot water(its on too)tank,water tank and some anti-freeze in the waste tanks. Only had the dump gate freeze up one time at the Grandcanyon, a hot towel took care of that problem.
Zero degrees that night.
2007 F-250 4x4 /6.0 PSD/ext cab/LB/camper pkg..Lance 815 ext. cabover
Get the camper you like and fit your needs
Alex and Julie's travels
Travelingman2
RV dump search
Recreation.gov
campground reports
magic43
Brookhaven, Ms, USA
Posted: 12/04/07 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
Definitely insulate inside the outside shower door. Even if you have the water turned off. This is a place for serious cold air intrusion. I used two layers of insulite. (The 1/2" blue pad that is placed under sleeping bags.) Look in all compartments and check to be sure that no water lines are against the outside walls. If so, use more insulite for separation. If the cabinet under the sink is not heated, then leave a cabinet door open.
magic43
JoeChiOhki
Keizer, Oregon
Posted: 12/04/07 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
I did some modifications to my plumbing for cold weather camping. First, since there's never city water available, I put in a cut off valve and blow out so that I could pressurize the camper's water system at home, then close it off below the cabinet level (Where the heat is) and blow it out so as to prevent freeze up.
I then bought several packages of foam pipe wrap and insulated all the water lines in the camper. Since in the case of my KIT, all the water lines run right at the front of the cabinets near the doors (About as far from the walls as it can get) doing this was fairly easy insurance of preventing a freeze up.
The last owner made window inserts for most of the windows in the camper, but forgot the door and roof vents. I made inserts for those. Thus far tested, I can keep the camper warm to 65 degrees with only occasional cycling of the furance in 20 degree temps (roughly once a half hour-forty five minutes). It will take a mountain adventure to give it even better test. But, I know at least that night, while having to live at work, the shower run off was freezing on the ground and there was frost all along the aluminum siding. But, the camper was toasty warm and fully water functional.
CB Channel 17 Space Ghost
'1991.5 Dodge W-250 Power Wagon - Club Cab Long Bed V8 5.9L 4spd H.D Auto 4x4 4.10 Gears
'1987 Pullman Mini Camper
'2004 Bi-Mart 4x8 Cargo Trailer
ORbiker
Eugene, Oregon
Posted: 12/04/07 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
I'll second the thought about insulating the outside shower compartment. I use the foil type insulation, but the insulite pad use is a great idea. I wonder what the R value of each is.
I (2-10-05) bought a 2002 F350 CC SWD PSD and a new 2003 Citation 10'8. Rancho 9000X & Toyo M55's.I have been a tent camper all my life. I wanted more comfort while doing my Willamette Backcountry Ski Patrol & Crater Lake Ski Patrol duties.11
GULFMAN
MOORESVILLE, NC,USA
Posted: 12/05/07 05:49am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replys
So would it be better not to use the the camp ground water outlet and just put some water in your fresh water tank.Can you use your water heater?
Gary
Troutguy
Brandon Twp. MI, USA
Posted: 12/05/07 06:01am Link  |  Quote  |  Print  |  Notify Moderator
Gary
Don't use the outside hose hookup unless you can keep water flowing through it all the time or it will freeze........just fill your on board water tank.
TG
2001 Red Chevy 2500HD X-Cab SB D-Max/Ally 4x4
2006 Arctic Fox 811S Truck Camper & Honda EU2000
2004 Clackacraft 15'LoPro Drift Boat
2004 Suzuki DR200 Dual-Sport motorcycle
2008 Suzuki DL650 V-Strom motorcycle
davidj54
South Alabama
Posted: 12/05/07 06:05am Link  |  Quote  |  Print  |  Notify Moderator
The reason for not leaving the CG water hooked up is to keep the hose from freezing and possibly bursting. I use those faucet covers on all my low point drains and to cover my city water inlet. I have a piece of 1" thick styrofoam cut to a press fit that I use inside the outside shower door to keep it from freezing. I'm not sure that bat insulation wouldn't work better but I've been in 8ºF and been fine.
Dodge Ram 2500 Mega Cab (Yeah, it's got a Cummins)
2006 Forest River Grand Surveyor GS-280
Prodigy Brake Controller
1000/10000lb Equal-i-zer with 4-way sway control
Windwalker55
Missouri
Posted: 12/05/07 06:19am Link  |  Quote  |  Print  |  Notify Moderator
I have been thinking of using my truck camper a little this winter for short excursions. I don't think I will use the water tanks since it is winterized. I'll just take along a couple of large jugs of water and work out of those. No showers but could still heat water in a kettle on the stove and wash up.
2001 Ram 2500 Cummins Diesel
Hitchiker II LS 30.5
Alpenlite Laramie LS850 truck camper
One wonderful life partner, my wife of 40 years
"I want people to know "why" I look this way.
I've traveled a long way and some of the
roads weren't paved."
