RV.Net Open Roads Forum: Truck Campers: Insulating outside shower, electric compartment (lots-O-pics
 > Insulating outside shower, electric compartment (lots-O-pics
Spott
SE Michigan
Posted: 12/07/07 02:27pm Link  |  Print  |  Notify Moderator
Here's my outside shower
I cut a piece of 1" rigid foam to a snug fit and carved out a notch for the door lock
I cut a slit with a razor blade to install Popsicle sticks at each end
I than drilled a hole with a small screwdriver (Phillips) to allow for the pull rope
installed in place, use pull rope to remove in the spring and the Popsicle sticks keep the rope from pulling through the foam.
* This post was edited 12/08/07 03:40pm by Spott *
Me - Kim - Spot
Dogbone
Ontario Canada
Posted: 12/07/07 02:30pm Link  |  Print  |  Notify Moderator
Nifty idea! Well done.
2006 Holiday Rambler Vacationer 35SBD
36ft Workhorse 8.1
Sailbad
Bernardo, New Mexico or Quartzsite
Posted: 12/07/07 02:47pm Link  |  Print  |  Notify Moderator
what a wonderful idea. Very neat and simple. Thanks...
Dave C.
2005 Silverado 2500 CC
Duramax 6.6 3.73 V-2
2003 Wildcat 27RL
B&W with Companion
Prodigy
Keep Your Powder Dry....This Ain't Gonna Be Fun
Steve_in_29
29 Palms (SEMPER FI), CA 92277
Posted: 12/07/07 03:25pm Link  |  Print  |  Notify Moderator
Great idea!
2007 F350,SC,LB,4x4,6.0/Auto,35" tires,16.5 Warn,Buckstop bumpers
2007 Outfitter Apex9.5,270W solar,SolarBoost2000e,2 H2K's,2KW inverter,2 20lb LP on slide out tray,4 Lifeline AGM bats,Tundra fridge
95 Bounder 28' ClassA sold
91 Jamboree 21' ClassC sold
dms
Walburg, Texas
Posted: 12/07/07 04:18pm Link  |  Print  |  Notify Moderator
Slick idea. Thanks. - d
2008 GMC 3500 CC D/A DRW 4WD
2007 Wildcat 27BH
2007 Lance 835
uva uvam vivendo varia fit
rhode trip
Rhode Island
Posted: 12/07/07 04:36pm Link  |  Print  |  Notify Moderator
A clever idea well executed, as usual, Bruce. Thanks.
2002 Dodge 3500 CTD/DRW/
2000 Northern Lite 10-2000cd
www.LapelPinPlanet.com
BRADY BUNCH
TN
Posted: 12/07/07 05:06pm Link  |  Print  |  Notify Moderator
SWEET! NICE JOB!
Raften
Northern Calfornia
Posted: 12/07/07 06:32pm Link  |  Print  |  Notify Moderator
You can also put a piece of egg crate foam cut oversize a bit to seal it up.
'01 Dodge 3500 CTD, Lance 1121, Air Bags, Rancho 9000, All Wheels Under Power When Needed, A Few Engine Mods For Increased HP
Burning Grease, 800 ft/lbs. of torque from something you throw away.
BMCM
Santa Clarita, CA
Posted: 12/07/07 10:23pm Link  |  Print  |  Notify Moderator
Don't forget the shore power cord opening.
Make a hole for the cord to pass through, and use a piece of foam pipe insulation to fill the hole in the rigid foam when the cord isn't being used, and to fill the gap in the door where the cord passes through.
F-350, Scorpion, QC, Dually/Alpenleak
All Gave Some,
Some Gave All.
davedave098
michigan
Posted: 12/08/07 02:34pm Link  |  Print  |  Notify Moderator
why ? -- just asking i never done mine -- and have no problems -- just run the juice thought it and run fresh water in the spring
When Life Sends You A Bunch of Lemons & Limes Demand Some Tequila And "Call Me for Help "
© 2012 RV.Net | Terms & Conditions | PRIVACY POLICY | YOUR PRIVACY RIGHTS
