RV.Net Open Roads Forum: Class C Motorhomes: Fresh water drain petcock
 > Fresh water drain petcock
cal47
Arcadia Fl
Posted: 12/08/07 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
I have replaced 3 in 3 yrs due to UV rays making the brittle. Thought I seen post where someone replaced their' with brass or copper and had pics. Searched forum but no luck, can anyone help?
Cal & Donna
Starr & HoBo (dog & cat)
2000 FourWinds Chateau 31S
1996 Grand Cherokee Toad W/Ready Brake System
Garmin 2610
Pressure Pro System
Sani-Con Sewer Solution
bukhrn
Lanexa, Va
Posted: 12/08/07 12:42pm Link  |  Quote  |  Print  |  Notify Moderator
Don't know about yours, but mine can't get UV rays,it's at the tank, under my bed, I'm sure there is some sort of brass one that will work.
2007 Forester 2941DS
2005 KIA Spectra
I Love My Grizz
trashman66
Nocatee, Fl
Posted: 12/08/07 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
Mine is under the dinette. I am trying to picture what yours looks like.
Cool Mike
Mendocino. Calif.
Posted: 12/08/07 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
I know what yours is like, its the same as mine, I think, If it mounted on the side with two screws, like mine is, its a bad place to mount it. I have not replaced mine from UV damage, more like a low sign in a gas station.
If you can deal with the holes in the side, mount a small brass ball valve from any hardware store under the coach.
2001 27' Four Winds Class-C E-450 V-10.
Buick Park Ave Ultra, Ford Ranger PU, JD 500 backhoe.
1941 Farm All "A"
skipnchar
Topeka Kansas USA
Posted: 12/08/07 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
Or put a piece of duct tape on it.
Kejsj30
Portland, Oregon
Posted: 12/08/07 10:51pm Link  |  Quote  |  Print  |  Notify Moderator
My old trailer (Fleetwood Gearbox) had a regular gate valve like your sewer dump gate valve, only it was smaller (1 1/2" to 2"). Worked well, never noticed any problems with it. Worked well, I could dump over 100 gallons of water, if needed, in nothing flat!
2008 Chevy Silverado 2500HD
2008 Keystone Raptor 3712TS
2000 Bayliner 2855 Sierra SunBridge Boat (SOLD)
2007 Raptor 700R
2007 YZF 450RSE
2008 Raptor 700RSE
BillyP
Cedar Point, NC
Posted: 12/09/07 12:17am Link  |  Quote  |  Print  |  Notify Moderator
This thread says the guy bought a brass valve to replace his at Lowe's: brass valve
You didn't say if your petcock is the barb or threaded type. I would recommend taking your petcock to Lowe's and other hardware stores in the area and have someone there match up a metal replacement.
Amberbunny
newport news
Posted: 12/12/07 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
Yup I got the same piece of junk petcock. Went through sall the trouble of replacing it with a brand new one . . . that leaked worse than the UV ate up one. I bought but have not yet installed my new brass valve that just looks cool. It was suggested to me to use one of those foam squishy ear plugs in it if it keeps leaking. Dripping water is amazing at producing volumes of water. I can drain a 40 gallon tank in what seems to be a few short hours.
\Documents and Settings\stephen.kunich\Desktop
cal47
Arcadia Fl
Posted: 12/13/07 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
Solved the problem, wll screw a door from Camping World to cover the hole where the drain valve is. Remove the cheap plastic petcock and replace with a brass one and just let the hose hang under the coach.
Amberbunny
newport news
Posted: 12/15/07 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
Well, yeah that would seem to work nicely too, and leave a finished spot on the side as well where it was. Never thought about letting it hang, but I don't see a downside there, long as it is there when i need it.
