RV.Net Open Roads Forum: Class A Motorhomes: Wheel Size
 > Wheel Size
ROYBUCK
Chester VA
Posted: 12/10/07 08:26am Link  |  Quote  |  Print  |  Notify Moderator
I will be bringing my 2002 Endeavor Home Thursday just purchased. I posted on another Subject (Spare Tire) I think I will purchase a used wheel if I can find one to have a spare, I don't have my manual with me are they any thing in the manual that tells me what size wheel's I have, if not how can I tell. Another forum member in the Spare Tire topic said they was a difference in size between front and real are they any thing to this. Thanks Roy
Roy B Coal Miners Son
USMC Ret
Semper Fi
Lug_Nut
Newmarket , Ontario, Canada
Posted: 12/10/07 08:33am Link  |  Quote  |  Print  |  Notify Moderator
No your front and rear tires are the same size. In your case 275 x 70 - 22.5
'07 Newmar Essex 45' ISM 500 4 slides
ROYBUCK
Chester VA
Posted: 12/10/07 08:45am Link  |  Quote  |  Print  |  Notify Moderator
Sorry Lug-Nut didn't explain myself I was talking about wheel size. Roy
chuck4788
West of the Middle
Posted: 12/10/07 08:48am Link  |  Quote  |  Print  |  Notify Moderator
Very few people carry a 22.5 wheel, some carry an unmounted tire. Several reason for this:
A mounted tire weighs close 170-200lbs, hard to lift.
An unmounted tire weighs 130-150 pounds.
The tire is almost 4 feet in diameter, difficult to store.
Lug nuts are torqued to 450 pounds, you need large air tools and air supply.
You need a 20 ton bottle jack to raise MH, not light and not cheap.
The 22.5 size is much more reliable than the 19.5 and 16.5 sizes.
There is a national network of road service providers servicing the trucking industry (22.5 size).
For all of the above reasons you will find that most owners of MH with 22.5 wheels do not carry a spare, they rely on the truck industry road service.
Chuck
02 Beaver
505hp C12 Cat
Trailblazer toad
dennis16002
Butler, Pa, USA
Posted: 12/10/07 08:55am Link  |  Quote  |  Print  |  Notify Moderator
You need a 8.25"x22.5" hub piloted 10 bolt wheel. A new wheel would be between 75 & 125 dollars. You can lift most of the coach weight with the leveling jacks, so a 5 ton jack will work, 450 ftlb of torque is a 3' piece of pipe on a breaker bar & 150# of your weight, & the mounted tire is 38". You can use the pipe to lever the tire onto the hub, weight that woy is less than 80#.
* This post was edited 12/10/07 09:02am by dennis16002 *
DHS
rob98801
North Central Washington State, USA
Posted: 12/10/07 08:56am Link  |  Quote  |  Print  |  Notify Moderator
Chuck hit the nail on the head. Also, paying to haul that extra weight ( tire and rim, tools etc.)around is not going to be cheap at todays fuel prices.
1999 Georgetown M-265
568th SMS 381st MIMS
Wherever I happen to park
Posted: 12/10/07 09:00am Link  |  Quote  |  Print  |  Notify Moderator
The tire size is on the tire, as others have said, they are all the same size. You tell a dealer what chassis you have and what tire you have and they know the rim size. However as others have said, if it's a 22.5 the cost of hauling the spare will likely exceed the cost of a service call if you should have a blow out, plus as it happens spares do not last as long as primary tires (With the exception of tires that are stored out of sunlight and specifically made to be spares, like the donut spare in your car) so I'd strongly advise against keeping a spare. Instead carry a bit of cash in your VISA debit account.
SteveRankin
Sequim, WA
Posted: 12/10/07 11:46am Link  |  Quote  |  Print  |  Notify Moderator
The Patriot next to us at a rally had his front tires replaced because he thought they were developing a funny wear pattern. They weren't that old yet so he gave them to us. So, now we have two spare tires. I'll built a tire carrier to fit on our tow bar extension for not much $$. We have over 3,000# of unused CCC on the rear axle, so the weight in not an issue. We only plan on carrying the spares when traveling to Alaska & such where a new tire can be expensive.
DW & I can manage moving an unmounted tire around, if needed, including getting it on/off the roof of the Jeep. I've worked with mounted tires more than I want to remember. A mounted tire is way too heavy to mess with.
Steve & C. J.
"Gracie" the Rough Collie & "Bo'sun" the Bichon Frise
2009 Arctic Fox 29V
2005 Chevy 2500HD Duramax 4X4 Crewcab
Hensley Hitch
TruControl Brake Controller
Our Beaver Technical page
Wildlife rescue at the Northwest Raptor Center
Norm Payne
Livingston, TX
Posted: 12/10/07 11:52am Link  |  Quote  |  Print  |  Notify Moderator
There should be a sticker on the wall behind the drivers set with the wheel size. You don't want to buy an 8.25" wheel if the motorhome has 7.50" wheels.
Norm
2005 Dutch Star 4015, Cummins ISL 370 hp
2007 Honda CR-V
See Ya Down The Road
http://www.seeya-downtheroad.com
John Wayne
Long Beach, Ca
Posted: 12/10/07 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
The wheel size should also be stamped in the rim it's self....
John & Carol
01 31'Sea View single slide, F53 V-10
96 Toyota 4-Runner auto 4x4 (Remco, M&G brake system)
KF6HCH
 > Wheel Size
