IbeDavid
Northern Illinois
javaseuf wrote: IbeDavid wrote: javaseuf wrote: I have done the following:
6' x 8' slide-out patio deck
Under cabinet halogen lighting over countertops
10 gallon water heater
1000 watt invertor
Digital thermostat for heater/AC
Digital timer to turn propane water heater gas system on and off
Wine bottle rack in place of a small overhead cabinet
Flourescent lighting
Oxynegenics shower head
Wall switches for overhead lights that only had switches on fixture
Olympian Wave 8 catalytic heater
Outside tacky lights to bother all of my neighbors
REPLY: Steve, I your digital thermostat is a 12 v. wall mount type, where did you get it ? I cant find one. Thanks, David
It is not a 12 volt. It is a standard residential White Rogers model that uses batteries for its power source. As long as you purchase one that uses batteries and is NOT hardwired or "power-stealing", it will work in a RV application.
Many are available at Lowes or Home Depot. The one I used is one that only HVAC distributors sell.
REPLY: Steve, Didnt know they could be used in an RV 12 v. application. I guess it could like you say, so long as the Thermostats screen power and operation is coming from its own AA batteries. I sure dont like the factory magnetic type ; such a spread in differential. Thanks.
PHILLIP300
Barnum, Iowa
Nice job on the slide out deck. Please dont let my wife see this, I already have enough projects this winter to keep me busy, but in case she asks, what did you use for the frame and slide mechanism?
pianojuggler
Not here
... Well at least ONE of your mods was practical.
But I am so-o-o-o-o disappointed! I thought you had done all those things to your PUP!!!
ridingfamily4
Corona, CA
not really a modification - but I do carry a shower curtain rod that I have put curtains on that I put up in between the "living area" and the bathroom area so that whoever is showering has more privacy getting in and out of the shower and I prefer using that to using the accordion door.
The one who laughs last, thinks slowest!
2001 Minnie Winnie
1999 Enclosed trailer
2005 Honda 400
2005 Suzuki 250 x 2
2002 Yamaha YZ85
2001 Yamaha Blaster
1991 Teenage Boy DRIVING
1995 Wannabe Teenage Boy
2000 Lab/springer spaniel
2001 Boxer
geysergazer
Not here
RV.Net editorial policies are unacceptable to me as a Poster.
edited 05/11/08 08:36pm by geysergazer *
Largestal
Lexington, KY
1. Business cards with my info, the rigs info, including license #, insurance info and emergency contacts.
2. Health card info and allergy info, including veterinary stuff for the mutt, in a red pouch put in a very visible place.
3. 27" LCD in place of the 13" ancient TV. On a removable, articulating arm with an extra mount in a side compartment for outside viewing.
4. Multiple inverters permanently mounted, sized for their respective uses.
5. Propane torch with push button ignition to light any fire in almost any weather.
SpoiledRotten
Central Mississippi
Replaced all of the cheap chrome plated plastic faucets with the real thing from a home improvement supply (both sinks and the shower)
Added decorative lighting above the cabinets in galley area.
Replaced both televisions and microwave. (not our idea. the other ones fried)
Added Plexiglas to the screen door so we can feel like we aren't closed in.
Added a receiver to the back of the 5er.
Ran dedicated coaxial for the Satellite receiver.
Ran auxiliary power from the transfer case to the front of the 5er so we can plug into the portable gennie in the back of the TV.
Add outside jacks for powering up the outside speakers.
Added smoke covers to the Fantastic fans.
Can't think of anything else right now.
Just the 3 of us...SpoiledRotten, TotallyRotten, and ALittleRotten
2000 F-250 Lariat, CC
7.3 PSTD-Superchipped
2005 33RL2 New Vision - AKA "SpoiledRotten"
2000 Jeep Wrangler Sahara Edition
tpi
Southern CA.
1. Replaced foam mattress with standard innerspring mattress
2. Installed accumulator tank in fresh water system
3. Replaced thermostat with battery operated digital thermostat
4. Upgraded batteries to West Marine (Deka clone) AGM
5. Ordered 1 Taylorbrite cold cathode fluorescent (linear style, 7 watt, 75 lumens/watt). If I like will order several more for under cabinet area.
6. 22 inch Vizio LCD HDTV from Costco
7. To do list: Shurflo Extreme 5.7 for steady water flow-existing pump has big swings between cut-in and cut-out pressure.
IbeDavid
Northern Illinois
Lew, Looks like you REALLY went to town ! Sounds like you had alot of Construction / Design experience and a ton of patience.
Hornet28BHDS
Parker, PA
Check out the TT forum and look in the Mod section.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
