Socalou
Hemet Ca
Well if Mark is a stand up guy he will not take the easy way out and file BK.He should stand up behind his product and fix every one that has problems from design or materials.
2006 Chevy Silverado Crew Cab
2007 WW FB2100 Super Lite Billet Edtion
2005 Z400 Suzuki Quadsport
2005 Z250 Suzuki Quadsport
2008 Yamaha Raptor 250
SAS!
So. Cal.
Socalou wrote: Well if Mark is a stand up guy he will not take the easy way out and file BK.He should stand up behind his product and fix every one that has problems from design or materials. If Mark files for BK you can probably thank the class action lawyers for their greed. IMO
2008 Rage'n Falcon 34-05
2004.5 RAM 3500 QC 4X4 SLT SRW CTD 600
2001 Bombardier DS 650
2001 Yamaha Raptor 660
2004 Suzuki Z 250
CORVA........The Action Program........The BlueRibbon Coalition ........aSa
blownsub
Dickinson, Texas
I have frame issues behind the rear wheels also with my '07 fs 2500. Max WAS my contact until a few days ago. He told me they moved him and someone else would be contacting me. But 3 days after first talking to Max, They picked up my trailer in Dickinson, Texas (near Houston). That was May 28. If they go BK wonder what happens if your trailer is in their possession? SOL??? The driver that picked up my trailer told me that a BUNCH of fs2500's were headed back or were already there being repaired. All with the same problems, frame broken or bent at or behind rear wheels. I only used mine for mountain biking at first (no weight). but the first time I put 800 lbs behind the rear wheels, the siding popped off and the inside walls buckled. They knew this was too flimsy from the start. I don't think there could really be such a thing as a "half-ton towable toyhauler". Only if you don't put anything in it!! Max did also make me a bunch of promises on different repairs also. Hope it comes true. good luck to everyone dealing with this situation.
Kent
2007 2500HD D/A 4WD CC SB
2001 Blown Suburban Z71 418ftlbs @2400@the wheels. Gone
07 WW FS2500 loaded w/everything except billet (next time!)
Hensley Arrow
07 KTM 250 XCFW
04 Honda CR230F
04 Yamaha 125 LE
fordqueen
Menifee, CA
I haven't heard anything regarding Ragen also being part of the BK, only WW.
2008 F350 C/C 4x4 6.4L Twin Turbo Diesel
2008 Heartland Full Throttle 3912
Quads
Boat
Kids
lngwca2600
Visalia, CA
Just so everyone knows. The issues with the frames of the fs2500 has almost nothing to do with weight, unless it is the tongue that needs fixin. The bending and breaking behind the rear axles is due to the lack of cross bracing from bottom of c-channal to cross members. this results in when a trailer is turning and the rear axles starts to cut, the leaf hangers are welded to the bottom of the c-channel, the the frame starts to tweak because there is no bracing. The fix from the factory clearly shows no signs of weight reinforcement but lateral reinforcement. I hope I explained that well enough. If you look and any other trailer frame you can clearly see that this was one thing was over looked in the manufacturing.
If you have questions on the fix from my fs2500 just let me know.
2004 F150 SC FX4, 6" procomp stage II, 35" mud grapplers, Edge Evolution Programmer, Intake, Husky WDH 1400lbs, Prodigy
2007 WW FS2500 Billet, swivel rockers, all the goodies
2002 Yamaha Banshee
Socalou
Hemet Ca
Did anyone get a letter from WW with a new weight sticker to put on your Toy Hauler? I got one the new sticker shows that the Toy Hauler's weight is more than the old one..
callen06
st.charles, mo
I got one.
And it told me what I had already figured out.
I have a fk2100 and I haven't had a problem and I am glad to see that there have been no posts with others having any either.
I am tying to get the "prophylatic" fix done on mine though. I also received the letter about the lighting not meeting safety requirements also. I am waiting on getting that fixed till I can find out if my local dealer can do it all. I wont have it shipped half way across the country just to get the tongue reinforced.
Macs Dad
SoCal
lngwca2600 wrote: Just so everyone knows. The issues with the frames of the fs2500 has almost nothing to do with weight, unless it is the tongue that needs fixin. The bending and breaking behind the rear axles is due to the lack of cross bracing from bottom of c-channal to cross members. this results in when a trailer is turning and the rear axles starts to cut, the leaf hangers are welded to the bottom of the c-channel, the the frame starts to tweak because there is no bracing. The fix from the factory clearly shows no signs of weight reinforcement but lateral reinforcement. I hope I explained that well enough. If you look and any other trailer frame you can clearly see that this was one thing was over looked in the manufacturing.
There was a issue with the tongues as well I thought. Made from 1/8" steel and bending up over time. They changed to 3/16" steel I thought.
We have a friend with a 06 FT that WW replaced the tongue on do to that.
07 Weekend Warrior SL2805
05 Chevy 2500 HD Crew Cab 6.0/410 Gasser
05 Honda 400 EX
07 Twister 150 GT
03 Honda CR 125
callen06
st.charles, mo
Mine already has 3/16 box tube on the tongue. But with all the stress it has on it especially with the e/h bars on it a little more couldnt hurt. I wish they would have made the tongue actually part of the frame and not just welded in. It sure looks as though it could be attached a little better.
blownsub
Dickinson, Texas
I would like to know what they did to yours if you do care to share. I'm sure there are others here that would like to hear also. There a lot of fs 2300 & 2500's out there with structural problems.
