larry and sue
burleson tx
Have a 99 endeavor has a small leak under dash by drivers feet, can see drops coming off a cable, traced cable to the backup camera, question is does the backup camera hook up to an antenna on the roof
BillGott
Loxahatchee, Florida
No the camera should be hard wired to the display on your dash. It is probably routed along the roof and goes by antenna wires coming through the roof.
2004 Winnebago 40' Vectra AD 350 Cummins Banks Kit towing a 2006 Saturn Vue.
On the road with wife Debbie and 3 Pembroke Welsh Corgi's, all fluffies, Tessie, Zack and Brandy
HPYHILM
Western Washington
Check your marker lights just below the roof. I had a leak that show up around the driver window, I kept sealing the window with no fix, then the leak also went to the floor under the dash. I checked the clearance lights and found one with the sealant gone, caulked it and no more problem with window or under dash.
Hpyhilm
NW Washington
99 DSDP Spartan
2000 Angler TC 8.5
fcooper
Richmond Hill, Georgia
My 2000 endeavor had no sealant along the bottom part of the clearance lights. Also had the windshield gasket (with integrated rain gutter) lose it's adhesive and become a rain funnel. Maybe one of these items is your problem.
Also check the caulk on the roof where the front cap meets the fiberglass roof. I have to periodically caulk the sides of this joint where there is no eternabond tape.
Fred & Vicki
Richmond Hill, Ga
2000 Holiday Rambler Endeavor/330 Cat
2000 Honda Odyssey toad w SMI Silent Partner braking system
Tire Sentry monitoring system
Wherever I happen to park
While the back up camera is hooked by cable. the back up cable is a long, long way from the dash, and the way that cable is routed a lead at the camera end while not impossible, would be... Well... Unusuall to say the least.
And for the water to make it all the way from the rear to the front.. Flat out impossible.
As others have said, look up front for the leak or spring for a SEALTEC 2000 test
This test is done the easy way, They pressurize your rig (about 1psi) and wash it down with soapy water,, Bubbles = leaks
MartyAndPeg
Jacksonville, FL 32204
I have to go with the marker lights. We had a similar issue on our Phaeton. Every once in a while we would notice water dripping down from the co-pilot side vent fan. Traced it to the marker light just above that location. My first clue was water in the lens.
Marty & Peg (and 2 cats)
2005 Tiffin Phaeton 40QDH/350HP Cat/MH3000
2007 Ford Ranger XLT 4x4/Brake Buddy
2007 Harley Davidson Softail Custom
Full-Timing-7 years and counting!
Looking for a purpose in life, try Habitat for Humanity RV-Care-A-Vanners!
Hyall
Davie, Florida
Are you sure its not condensation from your dash a/c duct above your foot that drips onto cable then the floor ? the tubing (duct)is not insulated which sweats at times
2007 Gulfstream TourMaster T40B MBE 926
2007 Honda CR-V
MC Honda VTX 1300R grey is faster
MC Shadow Aero 750 wife's
DON'T WORRY ABOUT NOTTIN - NOTTIN IS ALRIGHT
shinysideup
southern California
Is it possible your heater core is leaking? If you notice a "sweet" smell, that might be the anti-freeze solution leaking from the heater core. In autos, 90% of the time, leaks under the dash are heater core leaks.
Turn your heater off and see if that stops the leak. That would be my first guess, and only a guess.
