RV.Net Open Roads Forum: Tech Issues: The 'Whirrrrr' of an inverter.
 > The 'Whirrrrr' of an inverter.
SkullAndSquirrel
California
Posted: 12/20/07 10:29am Link  |  Quote  |  Print  |  Notify Moderator
teb1272 wrote:
One advantage to having been in the Artillery-I can't hear high-pitched sounds like that!! Would a simple shield like a piece of plywood or polystyrene insulation board between the generator and the MH help?
If you put your hand over the grill, the sound dissapears. Although, I suspect that is a good way to burn up a gen =P.
I did some experimenting directing the sound with 'sheilding', plywood in my case. It was pretty effective.
SCVJeff
Santa Clarita, CA.
Posted: 12/20/07 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
If you can't stand the 59.94Hz rap of over-modulated video, you should try the 15,750Khz whine of a flyback transformer in the TV. At 53 (I think) I can still clearly hear it across the room. In the 5th grade the school called "mom" because her kid's hearing was well beyond the capabilities of their equipment. It's top-end was somewhere around 60Khz. Mosquito repellers drive me nuts too. Although the generator doesn't bother me at all.
Jeff - WA6EQU
AstroBruce
Bucks County, PA
Posted: 12/20/07 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like a tight timing belt.
Regards,
Bruce
2006 Trailmanor 3124KB
Cummins Turbodiesel (Came with a 1999 RAM 2500)
SkullAndSquirrel
California
Posted: 12/20/07 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
I don't think I have ever heard a Mosquito repeller. That is some pretty high pitch hearing.
Retired Army SSG
Turner, Oregon
Posted: 12/27/07 10:46pm Link  |  Quote  |  Print  |  Notify Moderator
I enjoy each and every day, life is to short for me to get my shorts in a bunch over such a trivial sound....now if you were to scratch a blackboard with your finger nails, I could agree LOL seriously at almost 63yo there are a lot of sounds I just dont hear, or maybe tunethem out? Hope you can block it so you can enjoy your RVing more. Have a good one
SCVJeff
Santa Clarita, CA.
Posted: 12/28/07 12:26am Link  |  Quote  |  Print  |  Notify Moderator
You could always lick a popsicle stick
