diamonddogdogs
jacksonville florida
Need any advise ASAP! We are packed and ready to head north tomorrow morning at 7am and all of a sudden our tail lights are not working. Towing a Kia Sedona. Driving a 06 Gulf Stream.
Head lights work as do brake lights and turn signals. We were just walking around checking everything out they went out. Tried fuse and nothing wrong there. Help.......
BREWCO
Heart of Georgia
There may be a fuse box under hood, usually on left inner fender apron. You may need to remove the cover, look on underside of cover and usually there is a diagram of the fuse location. Check this out, as I'm not familiar with this model. I'm the Toyota Guy. Sorry if I'm of no help, but I tried.
2007 Toyota Tundra CrewMax 8262 - SR5 5.7L V8 Crew Max
2008 Coachman Chaparral Lite 267RLS
PullRite SuperGlide - 12,000
PullRite SuperGlide Trailer Plate Adapter Kit Part#: 3100
Mr.Mark
California/Tennessee
Are the lights NOT working on the coach or toad???
MM.
Mr.Mark
2008 Monaco Dynasty, 42ft., 4 slides, 425 hp clean-air Cummins diesel
2007 Honda CR-V EXL, AWD, w/Nav and the M&G braking system
diamonddogdogs
sorry i wasn;'t clearer - the coach.
frankandvicki
Niwot,CO
You may get more advice if you include your chassis info. Ford, WH or diesel/chassis builder.
Frank O.
Frank and Vicki
Niwot, CO
2006 Itasca Sunrise 35A
States visited/camped in, not just driven through.
Belgique
Cedar Island NC (Outer Banks)
On a Winnie 35J, Ford V10, there is a circuit braker panel by the drivers left foot. Over it is a panel behind which are a bunch of fuses. There is also a fuse panel in the "hood" area. The Ford manual lists all the fuses. Good luck! Steve
The Johnsons (incls a Bouvier, Lab, and Newfie)
Cedar Island, NC (Gateway to the Outbanks)
2008 Winnie Sightseer 35J
Our Mexico trip Blog
sh4717
Phoenix
I had a similar problem.
I hooked up a trailer and I kept blowing the fuse. I had to put in a bigger fuse for my tail lights in my coach fusebox on the left side under the dash. I went from a 5 to a 10 and that solved the problem. Just my input.
Scott
2002 Fleetwood Southwind 35r
SpinRite
Research Triangle, NC
Be sure to un-plug the toad until you have the coach lights fixed.
If plugging in the toad causes them to go out again, be sure that the interconnecting cable has not been rubbed bare somewhere. This can be very difficult to pin down if there is a bare spot which only touches ground once in awhile.
Good luck!
'94 Holiday Rambler Navigator
38', Cummins 8.3 300hp, Allison 3060
pushed by a 2005 Honda Element
scambony
arkansas
change both taillight bulbs.if they blow again,you need to put in a larger fuse in the coach box.i have had both bulbs blow when hooking up a toad.also check for 12v while somone presses the brake pedal.GOOD LUCK.
diamonddogdogs
thanks for all your replies - we are on the road. Changed the fuse last night and this morning just as we were pulling out of the driveway, the coach tail lights went out again. stopped down the road, put in new fuse and unhooked the trailer lights and coach tail lights still working. So it must be in trailer wiring. So now to have that looked into........
