RV.Net Open Roads Forum: Tow Vehicles: auxilary fuel tanks
Search only in Tow Vehicles
 > auxilary fuel tanks
jmramiller
Dallas
Posted: 12/27/07 10:39am Link  |  Quote  |  Print  |  Notify Moderator
why would I not want to remove the factory fuel tank cap? If I used all of the fuel in the aux tank and 3/4 of the main tank why would I not want to completely fill both when I stop for fuel. I would think that it would take some time for the feed from the aux tank to fill the main tank. I wouldn't want to have to hang around the fuel station that long. If the aux tank is empty what would be wrong with removing the factory cap to fill the main tank and then replace it before filling the aux tank?
2006 2500HD CC SB 4X4 Duramax/Allison
Prodigy/16K Reese/265E Tires/Bilstein Shocks
RM Active Suspension/RDS 60gal Toolbox combo
2008 Big Country 3490BHS by Heartland
rowdyrat
texas
Posted: 12/27/07 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
here is a link atta tank this place is in Mansfield, TX. Have seen there work did great job on dads truck. I will have them do mine when i get the extra money.
RGordon
Atoka, TN
Posted: 12/27/07 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
Clarification, if you have emptyed both tanks you would want to fill both tanks. I just keep the factory tank full and use out of the aux tank. If the factory tank if full and you have the aux tank valve open, you might have a spill out of the factory cap. It really is a good system when you get use to using it.
Ron & Libby Gordon
07 Ford F350 Dually Tow Boss Diesel
07 Mobile Suites 38RL3 #3698
02 Winnebago Adventurer 35U V10 (Former RV)
Learn from yesterday, live for today, hope for tomorrow
Dave H M
IL
Posted: 12/27/07 09:49pm Link  |  Quote  |  Print  |  Notify Moderator
jm
I do that all the time if i want to get completely toped off.
brohloff
Eastern MN, USA
Posted: 12/27/07 10:11pm Link  |  Quote  |  Print  |  Notify Moderator
"Did put filter on fuel line run every thing through alx tank. "
edwardt48 - This fuel filter you added, does the fuel gravity flow through this filter or did you have to pump it through?
Going to add a gravity flow bed tank, would like to add a fuel filter between and was wondering if the fuel would gravity flow through it or if a pump would be required.......
What size/type fuel filter did you use?
Or anyone with a gravity flow system, how did you set it up?
bob...
'05 3500 CTD SB SRW 4x4
'07 Tacoma 4x4 daily driver
'05 Nash 22H, Equalizer, Brakesmart
edwardt48
lady lake fl
Posted: 12/28/07 04:16am Link  |  Quote  |  Print  |  Notify Moderator
I used NAPA 4770 mount and a 6 micron filter NAPA 3352 from fleet filters. Yes it flows gravity. I don't want to change factory filter so I am running every thing through ALX tank and it keeps every thing fresh.
http://dieselplace.com/forum/showthread.php?t=68874
more than you wanted to know
