reddwar
Valley Center Ks. /Now Scotland SD.
Well 50K & 2 1/2 years no problem thenI had 3 GY614 blow up in 30 days & had some body damage on our HH so we stop at Chanute. Talked to a RV holler who had a 100 gal tank about this & he said if you keep it under 100 gal. tank then the DOT will leave you alone, over 100 gal. tank you fall under DOT. Have not checked it out but that is what he said.
red
jmramiller
Dallas
jdubh wrote: Anyone know of a manufacturer that makes a spare tank that goes underneath the bed? My grandpa got one from JC Whitney 15 years ago but they all seem to sell the toolbox combo today.
There are a couple. Titan is one.
http://www.titanfueltanks.com/
2006 2500HD CC SB 4X4 Duramax/Allison
Prodigy/16K Reese/265E Tires/Bilstein Shocks
RM Active Suspension/RDS 60gal Toolbox combo
2008 Big Country 3490BHS by Heartland
jdubh
Ohio
Thanks I'll check 'em out.
Wallaby
VAIL, CO
From memory there is also a company called "Supertank" or similar that does larger replacement tanks.
2006 FORD F-350 Lariat Crew Cab 4x4 SB SRW PSD w/TorqShift - BLACK
2004 H-D FXSTBI Night Train - BLACK
2004 Haulmark Transport enclosed trailer 6'x12' - BLACK
woodwkr
pendleton,ny
With all these aux. and stock replacement tanks, does the fuel info computer still work?????????????????
jdubh
Ohio
Only thing it would affect is the "range" on the current tank...probably have to reprogram and tell it you got a bigger tank.
bigdodgeram
southern Calif.
here is another company.
http://www.aerotanks.com/
95,Dodge RAM 2500 Club Cab, Red, SLT Laramie 2WD, 5.9 V-8, 46RH Trany. 5th Wheel Hitch & Tailgate. Tekonsha Prodigy brake controller. 1998 Fleetwood 28' Wilderness 5th wheel, 2 legged hitch support.
lovely wife, & Molly & Cassie our black & yellow labs.
marty649
Waycross GA (okeefenokee swamp)
woodwkr wrote: With all these aux. and stock replacement tanks, does the fuel info computer still work?????????????????
Yes, but mine only calculates from the truck tank. As I refuel in motion the DTE changes in reverse until the tank is full. I can refill 3 - 4 times before I need to stop to refill both tanks. We usually stop at rest stops for potty breaks, easy off easy on. I have a separate fuel gauge for the aux tank.
2005 Dodge 3500 Quad cab CTD Dually, Laramie, G56 sbc con-ofe, GPS-NAV, Sirius, intake and exhaust, Gauges, 100 gal aux fuel tank, Rokktech, Quad box, Pacbrake, 85,000mi
2000 Gulfstream Seahawk, Sat TV, Solar, 6.5kw gen, Washer/Dryer
2001 Roadking
RGordon
Atoka, TN/North Ft Myers, FL
I have the RDS 60 gallon toolbox/fuel tank combination that was purchased from Northern Tool. Have the gravity feed kit and it works great. Just always fill the aux tank and never open the factory fuel fill cap. The gravity feed is not illegal since it is a closed system and has check valves built in case of accidental roll over. The law just says you cannot gravity directly to a carburetor. On my Ford I do have to keep the isolation valve closed when I don't need fuel or the on-board computer will throw a check engine code for malfunction of fuel sensor. I just open when I need fuel or can fill when in route. If you leave the valve open all the time and after 3 or 4 tanks it will bring in a code. I have a code eraser so it is no problem. This is the best thing I have ever done to my truck and gives me close to 100 gallons of fuel with extended range. It is nice to travel and not have to worry about the next fuel stop and will I be able to get into it with my large rig. Do a search on this subject and you will find more information than you want to read.
Ron & Libby Gordon
07 Ford F350 Dually Tow Boss Diesel
07 Mobile Suites 38RL3 #3698
02 Winnebago Adventurer 35U V10 (Former RV)
Learn from yesterday, live for today, hope for tomorrow
edwardt48
lady lake fl
I have the RDS 91 gallon toolbox/fuel tank combination that was purchased from RDS. Have the gravity feed kit and it works great. Just always fill the aux tank and never open the factory fuel fill cap.
Did put filter on fuel line run every thing through alx tank.
