RV.Net Open Roads Forum: Fifth-Wheels: Towing Cargo Trailer w/Fiver
 > Towing Cargo Trailer w/Fiver
Mike@Asheville
Asheville, NC
Posted: 12/22/07 11:51am Link  |  Quote  |  Print  |  Notify Moderator
I have a Harley I'd like to take on some of my RV trips. Does anyone have any experience pulling a 10 12" trailer behind their Fiver. If so, do you need any special add ons like a rear camera. I have a F450 and a 36" fiver. The fiver has a hitch that can tow 2500 lbs with a 250 lb tongue weight.
Thanks for your help and Merry Christmas to all!
MH
2003 36.5' HitchHiker Champagne Quad Slide
2004 F450 Lariat 4X4 PSD Crew Cab
Fontaine Classic Hauler Bed 25K Pullrite
kaydeejay
SE Michigan, USA
Posted: 12/22/07 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
With a 36' fiver and an F450CC I suspect you are going to be over the 65' limit in most States. You need to check your local regs AND the States where you are going.
Where the license requirements may be reciprocal (ie other States recognize what is required in your home State) the length requirements are not.
Some States do not allow triple towing (AKA as "Doubles") at all, some (eg California) limit it to boat trailers.
Good luck getting all the answers you need - most DMVs don't know what is needed, even at home!
Edit, did a quick check, according this site NC does not even allow "triple towing", and has a 60' overall length limit. But I suggest it is worth checking out as not all of these references are 100% accurate.
* This post was edited 12/22/07 12:48pm by kaydeejay *
Keith J, Retired from GM Engineering
2005 GMC Sierra 2500HD SLE 2WD/CC/SB/DA.
1999 Sunnybrook 27RKFS Fiver
Bilsteins, Line-X, Westin steps, Prodigy, Retrax, 16K Superglide, 5th-Airborne pin-box, Multi-vex mirrors.
fj12ryder
Platte City, MO
Posted: 12/22/07 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
There's been a couple of threads about this topic just within the last couple of weeks. You might do a Search and see what you come up with. FWIW your home state, N. Carolina doesn't allow double/triple tows. Didn't stop me though .
Howard and Peggy
"Don't Panic"
LJ RV's
Corona, Ca
Posted: 12/22/07 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
In 05 we caravaned with a group from So Cal to Sturgis, SD MC rally. One of the couples had a Dodge dually towing a 30' fiver and 10' enclosed trailer with their Gold Wing in it. It seemed to handle well and we were never stopped anywhere. He had no camera to see it and no trailer brakes on this 2600 lb loaded trailer. Camera and brakes would seem to be a must for safety. He did have the 6spd stick and exhaust brake. Traveling at 60 mph behind it seemed very stable. I've heard your supposed to have an endorsement(don't know which one) on your lic in Ca to be legal towing doubles and 65' max length.
LJ
1995 Gulf Stream Tour Master 39' CTD 8.3 Allison 6spd
2004 Chevy EC LB 3500 Dually D/A LLY
Toys: Touring M/C's and Sand ATV's
rvcamperontx
Ontario / Texas
Posted: 12/22/07 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
You may have to consider an alternative trailer as the max length is 65 feet in most states that allow this setup. I had a custom trailer built. The length saving was made by having a very short tonque, this is ok with a bike. Good luck!
2008 Everest 344J - Quad Slides
2003 Silverado 3500 4X4 Ext.Cab 6.6L Duramax/Allison
2003 Vulcan Nomad 1500FI (MC in tow)
jdubh
Ohio
Posted: 12/22/07 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
A trailer pulling a trailer is the sweetest thing ever.
coeburn
Mount Juliet, TN
Posted: 12/22/07 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
I've pulled our 30' fifth wheel with a 16' flatbed loaded with ATVs and motorcycles all over NC, which supposedly doesn't allow them, and from our home in middle Tennessee out to southwest Colorado, over all the major passes and lots of winding backroads. We had no problems at all unless we needed to back up more than a few feet. We did install a cheap rear view camera we bought on e-bay for about $150.00 for peace of mind. The important thing to get right is your tongue weight on the tag along trailer. Too little and it'll wag the back of your fiver; too much and it'll upset the whole rig. About 10 to 15 percent of total loaded 2nd trailer weight should be on the tongue. We didn't have brakes on the second trailer, which would have been nice. Interstate speeds ranged around 70 to 75 and the rig was extremely stable. There was no noticeable drop in fuel mileage due to adding the second trailer. It drafts off the fiver, so there was little additional wind resistance. We were 66' over all with our TV of a longbed crewcab Chevy 6.6 Duramax. Gotta have the toys, don't we?
AZJeepnut
AZ
Posted: 12/22/07 08:56pm Link  |  Quote  |  Print  |  Notify Moderator
Brakes would be a good idea, and is the law here in AZ over a cetain weight. I would prefer surge brakes, though my 5,000lb Jeep does not have brakes when I flat tow behind my Thor.
I would strongly recommend a rear camera, got a nice one off ebay with an LCD screen for $200. Without the camera I cannot see the Jeep behind the trailer even with extended mirrors.
2007 GMC Allimax Crew 4x4
2005 Jazz 2780BH
F-TROUP
VISALIA, CALIF
Posted: 12/23/07 10:21am Link  |  Quote  |  Print  |  Notify Moderator
Becareful about shortning the tounge. As you turn your 5er's backend will start to swing, more than moving forward, if you turn real sharp. I can go on any streets, parking lots but can not make the turn in a culdesac. Other than that no problems.
Mike@Asheville
Asheville, NC
Posted: 12/23/07 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone for your feedback! Happy Holidays to All!
