Wxguru
Austin,AR
Is it possible for the freezer portion of the fridge to work and not the fridge itself? My freezer gets ICE cold, but the fridge itself doesn't seem to get cold....
It is a dometic 1999 model
1999 Keystone Cougar Ultra-Lite 261E
2003 Dodge Ram Quad Cab 5.7L HEMI
Rolling Condo
South Carolina
First question, have you used a thermometer to check? Because there isn't a fan to stir the air around, it may not seem like it is cold enough. Here are a couple of hints.
Inside the refrigerator in the back on the right side of the fins you will see a plastic clip with a wire. This is the thermister. Slide it up to the top of the fin. This should help some. Other remedies are to use a 'fridge fan' inside to help move the air around.
'90 GMC R2500 7.4L
'90 Avion 34V
Reese Dual Cam HP
Prodigy
Wxguru
Austin,AR
I haven't used a thermometer to check it yet...but I will go look for that thermister thing!
tuckerin
morristown, ny
Ice cold=32 degreesF Ice cream cold=-10F beer cold=uptou
skipnchar
Topeka Kansas USA
Some things that can cause the problem are having too much stuff placed in the freezer blocking the vents allowing cold air into the bottom or the fridge. Another is ice build up in the freezer compartment.
tomousecap
East Moline, IL
skipnchar wrote: Some things that can cause the problem are having too much stuff placed in the freezer blocking the vents allowing cold air into the bottom or the fridge. Another is ice build up in the freezer compartment.
Another is if your door switch isn't working and the light stays on warming the fridge. Just the heat from the light can really effect the unit.
Bob
2007 Fleetwood Bounder - Full Paint 35E
Workhorse 6 Speed 496 Cubic Inch V8 - W22
Ford fans - RPM is a poor substitute for Cubic Inches!
2005 Saturn Vue V6 AT FWD Toad - Love it!
Scavenger Power Exh. Installed.
Tenn Stud
Northeast, TN
Make sure that their is clearence between the back wall and the food stuff yiu have in the fridge. If it were me I would remove the thermistor from the plates at least overnight
FreshAir
Utah
tuckerin wrote: Ice cold=32 degrees Ice cream cold=-10F beer cold=uptou
Like said, Ice cold = 32F. First thing is to see that the freezer is cooling to about 0 or 10 degrees F. Make sure the freezer is working before trouble shooting the fridge. If not, we can go from there.
javaseuf
Southern Cal
Actually, in most RV fridges, if not all (because I don't know the specs for the newer side x side RV refers), there are no vents that allow cold air to migrate from the freezer. There is a separate freezer plate which is usually either the bottom of the freezer or the freezer shelf itself that is actually the cooling unit tubing, and the evaporator fins inside the refer section that is mounted to another section of the cooling unit.
Your description is a classic sign of a ammonia blockage in the small cooling unit tubes between the freezer and refer plates.
The cooling unit is defective but possibly could be repaired by "burping" (backflushing) the refer/cooling unit.
edited 12/22/07 09:37pm by javaseuf *
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
bfast54
Traverse City ,Mi.
javaseuf wrote: Actually, in most RV fridges, if not all (because I don't know the specs for the newer side x side RV refers), there are no vents that allow cold air to migrate from the freezer. There is a separate freezer plate which is usually either the bottom of the freezer or the freezer shelf itself that is actually the colling unit tubing, and the evaporator fins inside the refer section that is mounted to another section of the cooling unit.
You are right on , on all points.... I noticed a year before my unit failed, the fridge side did not seem to be cooling as well as should, then next year AMONIA SMELL , sounds like maybe yours is on the way south.
1994 Dodge Cummins Turbo Diesel,3500,Dually (Oh YEA )
1991 Ford F-150
1993 Sandpiper 5th Wheel)
Prodigy Brake Controller
Honda EU3000is Generator
Raytek IR Thermometer,Garmin C-330 Nav./GPS
Doran Pressure Pro
Rally's attended so far- 8
My Blog
