RV.Net Open Roads Forum: What size catalytic heater?
Search only in Public Lands, Boondocking and ...
Open Roads Forum  >  Public Lands, Boondocking and Dry Camping
 > What size catalytic heater?
Bill&Pam
If its winter - probably AZ, otherwise - who knows
Posted: 12/25/07 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
We want to add a catalytic heater to our 40' DP. What would be a good size and brand? The heater doesn't have to COMPLETELY heat the MH - just supplement the two furnaces, saving us some LP gas and battery power.
Bill & Pam, Somewhere, USA
South Dakota domicile
2007 Monaco Diplomat 40 SKQ
2005 Chevy Colorado TOAD w/M&G Brake system
2006 Honda Rancher ATV
gillguy
Valdosta, GA
Posted: 12/25/07 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
Olympian is a good brand. Depending on how much you use it the Wave 6 may be all you need.
Bobby (USAF Retired)
2007 Chevy 2500 LBZ Duramax C/C, S/B 4X4
2006 Rockwood 8317SS
1973 Airstream Ambassador
Old Town Penobscot 16
TiogaRV
Far West United States & Mexico
Posted: 12/25/07 07:46pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with the prior post about the Olympian catalytic heater. Here is a story about that heater with a bunch of info:
Olympian Catalytic Heater
George
Click to tune into:
The Adventures of Tioga and George
Dolph
Posted: 12/25/07 09:54pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Wave 6 (6,000 btu) in my 33' MH and it does a fine job of maintaining the heat.
Gadget Guy
Whitefish/Calgary
Posted: 12/25/07 10:30pm Link  |  Quote  |  Print  |  Notify Moderator
I use a "Mr. Heater" with great success. They make a 1 or 2 brick unit. I use mine with a length of hose attached to it so I can move it around to where I want to utilize the heat. They come with an automatic tip and low oxygen safety shutoff. I would add that the Olympian brand is also a good heater.
javaseuf
California's Gold Coast
Posted: 12/25/07 10:36pm Link  |  Quote  |  Print  |  Notify Moderator
If it's a Catalytic you are looking for, then it's the Olympian brand.
The Mr. Heater Buddy and Big Buddy do not use the true cataytic technology with a platinum impregnated pad like the Olympian.
I use an Olympian Wave 8 in my 30'TT and a Buddy in the PUP.
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
Bill&Pam
Posted: 12/25/07 11:39pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the info. Now I see why Olympian is more expensive than Mr Heater.
rockylarson
Jersey Shore
Posted: 12/26/07 05:15am Link  |  Quote  |  Print  |  Notify Moderator
We use a Wave 6 in our 30ft. Using the portable feature we can set it up mid-coach or in front on the doghouse. The Passenger side window has the screen on the outside so I open it about 1/2 inch for the required air supply. With the bedroom ceiling vent open an inch, the airflow keeps the heat and moisture generated going in the right direction.
Most of the time it is on the lower setting but occasionally it's nice to turn it all the way up. For a 40ft coach you may want the larger Wave 8.
As an aside, the airflow does not heat my storage tanks like the furnace does so I usually have it set up to only supplement the furnace. Meaning I keep it low enough so that the furnace still comes on several times a night instead several times an hour.
hohiso
Colorado Springs, CO
Posted: 12/26/07 05:32am Link  |  Quote  |  Print  |  Notify Moderator
There was quite a bit of good info about heater sizing in this previous post: Questions about the Olympian Wave 3 LP Heater
I used an Olympic Wave 6 in my small 25 ft single slide 5th wheel and it put out too much heat even at low setting. Had to downsize to a Wave 3 which works just fine. My usage is in relatively mild cold weater conditions.
Regards, Allen
2005 Silverado SB, 2500HD Crew Cab, D/A, 42 gal aux tank, Garmin SP III, XM Sat Radio,
2002 Nash 24-5N 5whl, 16K Reese Manual Sliding Hitch,
Tonka the Rat Terrier guards the rig.
Golden_HVAC
Fulltime, CA, USA
Posted: 12/26/07 06:28am Link  |  Quote  |  Print  |  Notify Moderator
I have a 6,000 Btu Olympic catalytic heater that heats my 30' Bounder when it is above 32 well, but below that temperature I might need to run the furnace a bit to send heat to all ends of the RV, basement and provide extra warmth.
You can check this website for a great price. Look at "Checkout" for the heater, leg kit, quick disconnect gas line kit and the dust cover - required to keep it clean for long pad life.
RvSolarElectric.com
Fred.
Money can't buy happiness but somehow it's more comfortable to cry in a Porsche or Country Coach!
If there's a WILL, I want to be in it!
Improve a life KangenPowerTeam.com Akaline Water.
I havn't been everywhere, but it's on my list.
Escapees.com
