RV.Net Open Roads Forum: Beginning RVing: Rving in below zero temps
 > Rving in below zero temps
JimMels-Rig
Tempe
Posted: 12/26/07 03:07pm Link  |  Quote  |  Print  |  Notify Moderator
Friends and family are going to spend a few days in northern Arizona.
We have a 38 ft 5er with a good heater from propane and at least 2 electric heaters. Have reserved a 50 amp hook up.
We will have hookup's but my concern is freezing up the water pipes and holding tanks. I have looked into the Ultraheat pads,but a little expensive. I figure I'll need at least 5 pads then what about the connecting pipes. ANY SUGGESTIONS! HELP!!
Ovaleye
Iowa
Posted: 12/26/07 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
How cold do you think its going to get?
Tim
2003 Safari Sahara
2006 Jeep Liberty
rv2go
Somewhere between Knoxville, TN and the coast.
I know that water is a precious commodity in AZ, but could you let the water drip at a good pace. This should keep the lines from freezing inside. Thats what I did last night. Dump your holding tanks and keep the grey valve open.
Winnebago Journey
TN Lic. RV 2 GO
1995 2dr. Hard Top Geo Tracker
www.rv2go.us
I'm here #4335
Travel Photos
skipnchar
Topeka Kansas USA
Posted: 12/26/07 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
Ultra heat is a really good product. Along with an enclosed and insulated underbelly they take the worry out of winter RV use. Good luck / Skip
JimMels-Rig
Tempe
Posted: 12/26/07 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
Ovaleye,it is possible for temps to get to overnight low of -5 maybe lower as we get into mid january!!
Golden_HVAC
Fulltime, CA, USA
Posted: 12/26/07 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
A lot of fifth wheels built now have a furnace heater line going into the basement storage compartment where the tanks are located. Also they put the battery charger there too, and that will give off some heat as well.
What I am doing is running a 1,500 watt heater inside and if I had a 50 amp service, then a 1,500 watt heater set on low heat with a thermostat set to about 55F will keep the tanks from freezing, and keep the area below the bedroom kinda warm under your feet.
You can run a heater in the bedroom, another in the kitchen, and a third in the living area. You will need to find 3 seperate circuits to put the heaters on, so you don't exceed 16 amps per circuit. Running two heaters on low will also work.
Then you will only need a little bit of furnace run time.
I don't like the oil filled electric heaters because of their large size and hot surface temperature. I also don't like the very compact ceramic heaters due to the 140F+ air output temperatures. I think it is hot enough to ignight something.
I have a small portable heater with a fairly quiet fan. Make sure you test the fan before getting one. It seems much noisier at night! It also must have a thermostat in order to leave it on at night - for automatic opperation.
Fred.
Money can't buy happiness but somehow it's more comfortable to cry in a Porsche or Country Coach!
If there's a WILL, I want to be in it!
Improve a life KangenPowerTeam.com Akaline Water.
I havn't been everywhere, but it's on my list.
Escapees.com
tatest
Oklahoma
Posted: 12/26/07 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
Some fivers have all the fresh and waste water tanks and plumbing inside the space heated by the furnace, either in the living area or insulated basement areas fed by ducts from the furnace.
Others have some tanks exposed underneath the floor, plumbing hanging outside (especially waste plumbing and dump valves) with no consideration for winter use.
There is a whole lot of variation in between, i.e. partial enclosure, with or without heating, enclosed tanks but exposed drain plumbing, etc.
What to do, to handle how cold, depends on where your trailer falls in this spectrum. If you have a well made four-season RV, most likely all you need to do is keep the furnace running. If you have a warm season RV, one of the best ways to cope with cold weather is to surround the RV with an insulating skirt, so that heat leaking through the floor will keep the space under the RV warm. This is how mobile homes cope.
Tom Test
Itasca Spirit 29B
2001 Ranger Edge
Ovaleye
Iowa
Posted: 12/27/07 06:33am Link  |  Quote  |  Print  |  Notify Moderator
To cold think I'll stick with Yuma........
BurbMan
Long Island, NY
Posted: 12/27/07 07:18am Link  |  Quote  |  Print  |  Notify Moderator
Also bear in mind that the fridge won't work properly at temps below freezing....the ammonia absorbtion process gets pretty inefficient. There was thread recently in Tech Issues on this.
Mousefart
New Jersey
Posted: 12/27/07 09:37am Link  |  Quote  |  Print  |  Notify Moderator
Fred.
Just an FYI to make you feel safer...
The ignition point of paper (probably the most flammable thing you would have in your RV) is 451 F. The ignition point of gasoline is actually HIGHER at around 496 F.
The hot air blowing out of you RV furnace AND the forced air furnaces in people's homes can be up to 200 F.
Hot water baseboard heating systems run between 180 F and 200 F.
As long as they are UL approved (with overtemp cutoffs), those little heaters aren't going to ignite anything at 140 F.
Paul (Mouse)
2007 Flagstaff Shamrock 17 Hybrid (heavily modified for boondocking and winter camping).
2007 Dodge Dakota Quad Cab 4x4, 4.7L HO, factory tow, 3.92 gears.
Equil-i-zer Hitch, Prodigy.
Yamaha EF2400 Generator (quiet, cause I care!)
