overbudjet racing
guelph ontario
We encountered some road debris and it appears that I lost the exhaust tip about 400 miles back. Is there any where I can get one of these or is there an after market solution?
bill
Agrnbrt
NJ, U.S.A.
yeah, Midas, pep boys, Advance Auto, WalMart etc...Or spend the big bucks and go to your RV dealer.
Maybe it's a rare item in Canaduh?
08 Jayco Eagle Super Lite.
07 Chevrolet 2500HD Classic. Reese 16k hitch & S/C tailgate.
Camping with: 1 Wife(Teri)
4 cats, Trouble(the Stynx),Seamus O'Fuzz(Buddha Kitty),Minx(tailless Buddha Kitty)& Bubba(the Love Sponge)
Oh yeah, one Sig P220 .45 acp.
ronfisherman
SE Michigan
overbudjet racing wrote: We encountered some road debris and it appears that I lost the exhaust tip about 400 miles back. Is there any where I can get one of these or is there an after market solution?
bill
Should be a 3" pipe. Try a truck stop or Canadian tire.
Saf-TTE tire monitor
overbudjet racing
guelph ontario
Agrnbrt wrote: yeah, Midas, pep boys, Advance Auto, WalMart etc...Or spend the big bucks and go to your RV dealer.
Should I just put a Chrome tip on it? What about the exhaust cooling that the other tip had or is it even necessary?
ronfisherman
SE Michigan
Do you have a 2007 engine with the wide flared exhaust. If you do you may have to contact a dealer. Should be under warranty on a 2007.
overbudjet racing
guelph ontario
Yes it was but I am sure that road hazard will not be warranted, was does that tip actually do?
ronfisherman
SE Michigan
It's part of the emission system. I believe it spreads heat when the particle filter is regenerated (not sure what the proper terms are). Stops weeds or anything else near exhaust from catching fire.
overbudjet racing
guelph ontario
o.k. the real question - what are these things worth?
ronfisherman
SE Michigan
overbudjet racing wrote: o.k. the real question - what are these things worth?
I do not know. But whatever it is in USA. It will be at least double in Canada.
paulin
No. CA
ronfisherman is right, it is part of the emissions system on post 2007 Kodiak diesels. The exhaust filter (PDF) automatically regenerates (cleans) using VERY high exhaust temperatures. I don't think a regular exhaust tip would do.
Paul & Linda
2007 Jayco Seneca HD 34SS Duramax
2005 Saturn VUE
"Monty", "Maggie" & "Murphy" the mighty Shih Tzus
FMCA #F375077
