Horsedoc
Dixie --- N. Georgia
We pour Pine Sol and some Ivory liguid in the black tank then turn on the flush system for a few minutes, then empty and let it rinse for a while. Usually will clean the sensors pretty good. Then a small amt in the tank with a couple gallons of water and it smells much better.
NGRRFan
Colo. Spgs., CO
My wife used to put Pine-Sol in the black tank, but after having to replace the toilet valve AND the black tank drain valve (no fun at all) I never let her use it again!
Rich,and Tobi (the rescued dog)
Prowler 5ver, 84 Ford F250
KCOCOLOR78 Weather
Colo. Spgs. CO
jenks60
MS. coast
We use it in both tanks, haven't seen any problems from it yet.
jenks, fulltiming with the DW.
92 Southwind P3(32) 33 ft.
99 Saturn SL2
Rallys attended-TX 2, LA 2, MS 1, AL 2
MA. 1 drop in for visit.
kalynzoo
Los Angeles , California
I have always, for 25 plus years, used Pinesol in the holding tanks. About 2ounces in the gray tank after I flush, and about 4 ounces with a gallon of water in the black tank when it will sit for a long time. It works for me, and I have never had a seal problem. As for how I got the idea...my wife said to do it, and it was done without question. Happily married for 40 years.
CW Gilley
Kinder, LA
I pour in a cup of that and a couple of gallons of water after each dump and cleaning, into each gray tank. Black gets it's own treatment. I figure that way it sloshes around in there going down the road and all ways smells better than doing nothing.
Clayton & Charlotte
2007 SunnyBrook Mobile Scout/Titan 34BWKSLX & Mor/Ryde Pin Box
2008 F-350 SD Lariat 6.4L PSD TorqueShift w/Tow Cmd 3.73 LS SRW
Super Cab Long Bed Firestone Ride-Rites & 20k Reese Pro Hitch
2manytoyz
Central FL
I tried it after reading about it on this forum. Worst thing I've ever tried, bar none.
Maybe it's because the bio action in the FL heat is much worse than other states, dunno. But 24 hours after pouring this in, the stink was unbearable. Pine scented poop. Argh!
I've tried a number of chemicals, and the only thing I've found that works effectively during the Summer are those with Formaldehyde. They stop the production of the bugs causing the stink.
Might be fine for flushing & cleaning a tank, but I wouldn't recommend it for odor control, at least not in a hot climate. But don't take my word for it, try it yourself. Just have something stronger on hand if it fails you.
Robert
Cocoa, FL
2007 Rockwood TT 2502
Equalizer Hitch
Prodigy Brake Controller
2005 Nissan Xterra
2006 Jeep Wrangler Unlimited
Yamaha EF2400iS
country1nphx
Phoenix
2manytoyz is correct about using it in the heat, it does produce an overwhelming stench, a pine tree in your toilet... Just use tide and some bleach. That will clean it without all the odors... Then just use tide all the time instead of chemicals, you won't need to "freshen up" your tank every again... http://cbruni.googlepages.com/
vic46
Red Deer, Alberta, Canada
2manytoyz wrote: I tried it after reading about it on this forum. Worst thing I've ever tried, bar none.
HHHHHHHHHMMMMMMMMMMMMMMMMMM smelled like someone pooped under a pine tree?????????????????????????
Big Katuna
Deland, FL
Must have put too much in or not put five gallons of water in first. I live in Florida and have used PineSol for years and I think it works great. My tanks are so clean, they look new inside.
My Kharma ran over my Dogma.
Burro
U.S.A.
We use a capful of liquid water softener and 2 oz. of Pure Power. Have done so on all our RVs over the years. Never any smells, bad or otherwise, and never had a clog problem, either. The sensors work fine all the time.
Pure Power liquefies everything. I'd be leery of bleach because it kills all germs, both good and bad. Good germs are, well, a good thing.
