RV.Net Open Roads Forum: Towing: Brake Controller
Search only in Towing
Open Roads Forum  >  Towing
 > Brake Controller
Page of 9
hotrod4x5
Fulltiming Southwest USA
Posted: 01/31/08 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
So it's a voyager with a digital display I guess. I didn't like my voyager.
Rodney 2005 Laredo 29GS 2002 F250 V-10 Hughesnet Satellite Internet
HEMIDAZE
Amelia, OH
Posted: 01/31/08 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
I posted the link so it would save me a lot of one finger typing. The Predator DX2 comes with a 7 year warranty. How does that compare to the others out there?
Dexter Predator DX2
2001 Salem 27BH by Forest River w/Barker 3000
2003 Dodge Ram 1500 HEMI 5 speed auto 3.92s Quad Cab 4X4
hotrod4x5
Posted: 01/31/08 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
Prodigy has a lifetime warranty.
tburke1
K.C. MO
Posted: 02/02/08 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
I just replaced my Prodigy with a Maxbrake. I have not towed with it yet, but I will give a update on its performance when I do.
2004.5 Dodge Ram 3500 DRW
2005 New Vision 41kgx2
hotrod4x5
Posted: 02/02/08 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
Can you share with us what led you to to make this change?
chadsalt
sc
Posted: 02/04/08 10:45am Link  |  Quote  |  Print  |  Notify Moderator
Ron Gratz wrote:
crappie_fisherman wrote:
When I simply lift my foot off the go pedal...and NOT on a downhill section of the road...doesn't rolling resistance of 8 tires minimum on the pavement also begin to shed some speed without the motor pulling the setup?
Therefore even if I simply lift my foot and lightly touch the brakes 'just enough' to activate the brake light circuit and 'WAKE UP' the brake controller (Prodigy/P3) doesn't the accelerometer SENSE the deceleration of the TV thru rolling resistance too?...deceleration is deceleration and the accel really senses that the TV is slowing (regardless of how hard I press the brake pedal)...so in that case if the TV is slowing thru rolling resistance and I hold the brake pedal LIGHTLY to LIGHT the brake lights...wouldn't the Prodigy apply a proprotional power to the TT brakes AFTER the inital boost?
Joe, that's a very good point.
If you're on a level road and you take your foot off the accelerator pedal, the rig will decelerate -- partly due to the rolling resistance and, to a greater extent, partly due to the aerodynamic drag on the TV and TT.
This means that if you release the accelerator pedal and lightly touch the brake pedal so the brake light is activated but with no significant TV braking force, an accelerometer-based controller will sense the friction/drag induced deceleration and will produce TT braking. A BrakeSmart (with the IBC turned off) would not produce any TT braking under these conditions.
Ron
Performed the above mentioned "experiment" this weekend while hauling my horses (7000# GN). Applying the brake pedal just enough to active the P3 at ~45 mph would result in 0.4 volt showing on the display.....interesting.
If the Prodigy/P3 had an adjustable Boost setting, i.e. user defined % as opposed to to 13%, 25%, and 25%, or maybe a constant (also user defined) voltage applied while brake light is lit........I wouldnt have a single complaint about it. Are you listening Tekonsha?
jlnix
Georgia
Posted: 02/04/08 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
What disturbs me about this thread is that fairly early on someone mentioned that they paid $30000+ for their integrated controller from Ford, but they thru in a SuperDuty truck. I'm disturbed because I paid a good bit more than that and still just got a SuperDuty thrown in!
1992 Avion 35.5 5th Wheel
2006 F-350 King Ranch
6 liter PSD Torqshift Tow Command
bjbear
Cold Lake, AB, Can
Posted: 02/05/08 09:07am Link  |  Quote  |  Print  |  Notify Moderator
Well based on this discussion, I had decided I should probably buy the Brakesmart. However, when I went on their website, I was definitely not impressed. I wonder about the quality of the product when I see such a poorly put together site. I then sent them an e-mail asking them to clarify the brake disconnect feature and how I can purchase a unit. So far no reply. I am reconsidering the Hensley as I have delt with them in the past (T3 Hitch) and their service was outstanding.
2003 Dodge 3500 DRW HO with:
Edge Juice
Banks Ram Air, Pac-Brake, Exhaust
ATS 5-star Torq Conv
ATS Hi-Perf 48RE Trans with Billet Input Shaft
Trailersaver T3 Hitch
2005 Komfort Karryall - 36 foot
2006 HD Electra-Glide FTHCI
2 - Kaw Brute 650i Quads
squaredancer
Garden Grove, Ca
Posted: 02/05/08 09:33am Link  |  Quote  |  Print  |  Notify Moderator
bjbear,
Judging website construction vs. product construction cuts both ways, i.e. crummy web sites-excellent product; excellent web sites, crummy product. I'm here to tell you that the Brakesmart is a both a first class product and a user proven product. It requires essentially zero support.As far as contacting them, I haven't had any problems, either via email or phone. Then again, maybe they're having a bad hair day. They're allowed.
2001 F250 7.3L PSD, air lifts, 4" pipes, 6637 mod, Husky sliderhitch
2005 Crossroads Cruiser CF29CK (with all the goodies)
62cwil
Carlsbad, CA
Posted: 02/18/08 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
Barney, your reviews are very informative. Currently I have the Prodigy but wanted your opinion as to upgrading to the new P3. Altogether I am 20,100 pounds and have never gotten my trailer to lock up like the Prodigy instructions say. When I called Tech Service they say sometime they want. I have my setting at 8 and use a boost of 3. I just recently replaced my trailer electric brakes at just over 10,000 miles. What is your opinion --- should I stay with prodigy or move over to the P3.
McKenzie Lakota 34SKT
Ford F250 7.3 PSD
Superchip Tuner
BD X-Monitor Gauges
Prodigy Controller
Ford AIS Intake System
AFE4" Mandrell bend muffler
PacBrake Exhaust Brake
Brk Guard
Firestone Air Bags
TrailAir Pinbox & Suspension
Voyager color rear camera
Page of 9
 > Brake Controller
