RV.Net Open Roads Forum: Fifth-Wheels: What can I Tow with my 2500 Ram????
 > What can I Tow with my 2500 Ram????
mopp4
In the camper right next to you
Posted: 01/19/08 10:16pm Link  |  Quote  |  Print  |  Notify Moderator
Ahava, do yourself a favor and go to this website. Dodge Towing Guide
Compare your 2500 SRW Quad Cab long bed to a 3500 SRW Quad Cab long bed. Understand the only difference between the two is an overload spring on the 3500. If you add Timbrens, airbags or the overload spring you essentially have a 3500 SRW (ok, for the sake of the paranoid weight police you are minus the sticker on your door) but everything else is the same; axles, brakes, etc.
To help you understand weights, here is a link to a Weight Demonstrator, this will allow you to make several comparisons to the trailers you maybe interested in and truck capacities mentioned above. Play around with the numbers and then make a decision you are comfortable with.
Sadly I do think you will need to loose the lift on the truck if you want a fiver.
Take care and I hope you to see you on the road!
* This post was edited 01/19/08 10:55pm by mopp4 *
2008 Wildcat 32QBBS
2006 2500 Dodge Mega Cab 4x4 CTD
Do not click this link
mopp4
Posted: 01/19/08 11:10pm Link  |  Quote  |  Print  |  Notify Moderator
* This post was last edited 01/19/08 11:39pm by mopp4 *   View edit history
